Interior lights
Scoobystig
17
17
My wife has managed to get an amazing purple colour in the interior lights
this has just happened and not been programmed
also there is no colour option for the purple. Which i really wish there was
luc
Sep 10, 2021
Purple is only available as the default colour for "Individual" settings, if you pick another colour in the Individual screen you don't have the ability to choose purple again.
The only trick you can do is to become again the primary owner of the car or add another user to the car, this will reload the initial setting for the Infotainment for that particular user.
MrBiggles87
283
196
Is it that bright in the flesh?! I love it.
Widil
108
22
Are you sure about adding a new user which will revert back to initial setting and having purple again ?
luc
Sep 10, 2021
Yes, just make sure you have both keys in the car to become the primary user again.
Widil
108
22
Great, I'll try that later this week.
Upgrading to version 1896, I've got purple color out of the garage but then adding my user account (which was erased following the update), it changed to my old choice which was calm (teal color).
I've been trying to find a solution to revert to the initial setting and even resetting the infotainment did not work.
However, I'm no more primary user following the reset.
I'll try both option, setting myself as primary user again or setting a new user.
If it works, I'll be very thankful to you.
Widil
108
22
Well unfortunately, my Leon is now buggy and I can't add myself as a primary user or add a new account.
Guess I'll have to head to seat first before trying your solution.
John Wick
138
67
What's the easiest way/method to reinitiate purple as the standard colour in individual settings?
Korefan
36
Latvia
I can switch it back and forth how many times I want.
/dev/null
1,649
101
Anyone been able to get the yellow from the preset "warm" mood in individual settings? I want that colour but less bright, however it doesn't seem to be in individual settings.
Widil
108
22
So you can confirm that by adding a new user, you get the purple color again ? my car is going for a reset in august, so I should be able to test this theory.
ChrisGerr
34
34
Hi Guys, I have just the one profile on my VZ3 and can switch between any colours in Individual mode (inc. purple) - Car was delivered April this year and running 1890....maybe I'm just lucky?
Chris
Korefan
36
Latvia
I received my car couple months ago, so it came with all possible software updates. Maybe because this.
I don't need to add users or do any other stuff. It just works as for @ChrisGerr
/dev/null
1,649
101
Chris
Have you got the "yellow" as an option? I.e. the one from the "Warm" profile?
/dev/null
1,649
101
Just been out to check and no :rolleyes:
Typical. 🙄 At least it's not just me.
I've also noticed on one of the other presets (can't remember which exactly), the door lights are completely out of sync with the dash colour. I.e. the door cards are red, but the dash is blue. 🤷
oldgitdave
508
240
UK
Well they are independent of each other :unsure:. I have my dash in an orange and door cards in red at the moment. Can't find the elusive purple on mine though.
Bear
300
273
You can set the dash as one colour and door as another.
