I will replace them with stock, my car is nothing special and I can’t afford it at the moment
Stolen from an old thread, as I was thinking about doing mine at some point... I don't think they're too expensive either...
"Passenger side.
Remove trim on back of headlight.
Remove battery cover, undo battery terminals and remove battery.
Remove battery tray.
Remove air box/induction filter
Pull top off the wire trunking.
place jack under gearbox to support it
Undo the 5 engine mount bolts 2 18mm 2x 16mm and I think 1 13mm remove mount and replace with new one.
Drivers side.
Remove 2 screws from header tank and unplug multiblock.
Undo the allen head bolt holding PS pot on
Remove 2 10mm bolts holding in carbon canister and unplug it
Remove 2 13mm bolts holding bracket from inner wing to top of engine mount
I didn't actually remove any of these things just unbolted them so I could get to the bolts
Support engine with jack
Remove 2 18mm and 2 16mm bolts and remove mount, replace with new one"
