The issue with aftermarket or these one anyways is that I don't know the information on them. Now prior to me changing any brake shoes and drum there was definitely no fouling and they were using the same bolts as in the pictures below. It is only the one side that started having the bolts foul on the brake shoe hardware internals after I changed the shoe, hence me thinking it is more of an issue my end rather than the bolts them selves. I believe the bolts are within the OEM specifications you mentioned earlier.One other I'll add here, for anyone that is interested, is, on all normal VW Group cars, using wheel bolts that end up projecting any more than 17.5mm from the rear face of any wheels or any wheels + spacers is just not correct as these bolts are M15 so full strength bolt to hub, is reached easily by this point and that includes adding 2.5mm to cover for lead in both on the bolts and the fixing holes in the hubs.
This is a safe general statement as it includes both VW Group wheels along with VW Group bolts with spherical seats, or aftermarket wheels with any spherical seats, or aftermarket with taper seat bolts.
Aftermarket wheel suppliers are usually a bit lazy so only list and supply maybe 3 bolt lengths to cover maybe 7 bolt "needs".
Unless you have done a lot of checking both at the front hubs and the rear hubs, you are only guessing what "bolt projection length" is always safe for both front and rear instals. Finding out that came from me needing to check if the bolts supplied for use with aftermarket wheels were okay, the other issue is, if you have a longer than necessary section of wheel bolt sticking out from the back of the hubs, but still keeping clear of any other parts when the wheel is rotating, they will get even more nasty curd building u on them, and that extra curd being forced back through the hub fixing holes is only going to lead to more frustration and maybe extra wear on these hub fixing holes when you get a puncture and that is the only time you ever remove wheels.
Sent from my moto g(8) plus using Tapatalk
