mendez
45
8
West Midlands
Got excited cos my riv nuts arrived, then realised my drill was flat. On the flip side noticed when I pulled out my parking space on full lock either way when I first set off I get an odd crunch from the front left, like I’m driving over sticks. I have 2x new shafts and cv inner and outer. Wheel bearings?
Maybe suspension top mount. My passenger side had water ingress due to a blocked drainage hole...ended up rusting the top mount bearing. Replacements are cheap
Reactions: Sl1ced
Sl1ced
797
404
Maybe suspension top mount. Mine passenger side had water ingress due to a blocked drainage hole...ended up rusting the top mount bearing. Replacements are cheap
How could I diagnose this mate?
mendez
45
8
West Midlands
Jack the front end up (preferably on jack stands) so the suspension isn't loaded and remove the wheels for head access if needed. Turn the steering wheel lock to lock and see if the noise goes away. The noise might changed to a more " quieter grinding noise" if it's the bearing. Also gives you the chance to check shafts etc
Sl1ced
797
404
It happens as I’m pulling away really slowly
Connor H
1,037
511
Essex
I recently had this when stopping and pulling away a slow creaking grind
Turned out my subframe bolts were loose, the bushes are prob shot to sh1t now lol
Sl1ced
797
404
It’s only as I pull away slowly, if I’m on full locks either way and always front left wheel
mendez
45
8
West Midlands
If it doesn't happen when you pull off straight, then it's something to do the steering components...like cv outer joints & top mount bearings. The top mount allows the shock stut and spring to rotate as you steer. Cv joints can split and leak grease everywhere and dry out the joint causing a grinding and popping noise. Either noise can be located by jacking the car up (safely) without the wheels on (y)
Sl1ced
797
404
Ok thanks mate like I say I’ve only just replaced both shafts complete. Will have a check of the top mounts, actually they was an advisory on my mot history I looked up maybe two years ago
