Exactly - I have a vacuum syphon pump that goes down the dipstick tube - https://www.toolbayuk.com/products/...r1zjZBTt438IO5Pe4I6BhIrM-aOGFBbxoCnEkQAvD_BwEwhat do you suck it out through a hose or something haha, Whats ya secret?
He runs the car till it’s empty then just puts a tub of fresh in
I might have to mate! Would save me running around with a sump bolt looking for washers lol. Ill send you a pm at the weekendYour'e more than welcome to .....your'e only down the road as well.
I've done maybe a dozen oil changes now and never once removed the sump plug......
I refuse to go in them!Ahh memories of multi-story carparks with my MK1 LCR - winced every time
I'll have you know that my car is very standard in ride height.....but takes on that slammed appearance (think thats what you youngun's call it) oddly when I get in it ......That happens a lot with lowered cars and speed bumps.
STANCEI'll have you know that my car is very standard in ride height.....but takes on that slammed appearance (think thats what you youngun's call it) oddly when I get in it ......
Replaced a few perished hoses here and there. One thing I have noticed is since fitting the forge TIP it sits very close to the top corner of the engine. Gonna get the Pcv delete and a catch can in at some point
It’s very tight there’s not really much room to move it at all with the way everything is in the way. I’ve got probably 10-15mm rotation on it. One of them skanky metal vac lines is in the way and I’m worries it’s going to rub so they’re coming out over the weekend lol
The 18 reg Scania I drive at work was serviced last week. Day after the low oil warning light came on.Does it leak that much... topping it up that often is classed as an oil change..
On the oil change note. I just serviced a merc 2545 artic unit.... 57 litres of oil the bugger takes. View attachment 19674
