Okay chaps cover your kids eyes because this is adult content
Gonna be one hell of a car. Looks like it'll fit nicely into time attack seriesOkay chaps cover your kids eyes because this is adult content
Sent from my SM-G988B using Tapatalk
Hit me up for a second driver....mean while I'll be practicing in the m3Well ... signal is bad and won't let me up load pics
I am more thinking of endurance racing and pit stop etc..
Drove to Brighton today for a weekends fishing.
Parked in Brighton marina multi storey carpark.
Front splitter hit the ground at the bottom of the ramps between each floor.
Pulled into the travelodge carpark, hit the splitter on a curb ?.
Amazingly its still on there. Will check for damage when the rain stops.
Oh, and drove up a bus lane, stopped, reversed back onto a main road. So will be waiting for the brown envelope through the door in the next week or so.
Not been a great day carwise.
Pulled into the travelodge carpark, hit the splitter on a curb .
Is the dog bone made from ally?The worst bit about the dog one mount is taking it off - the bolts connected to the chassis tend to snap if your not careful
Both of the red bushes are needed
Will be why it seizes then. Meterlergic reaction between the steel and ally. Ive been learningYep, well the replacement from TPS was.
Yes, they all are. They regularly suffer with galvanic corrosion where the steel bolts passes through the aluminium mount body.Is the dog bone made from ally?
Think mines gunna end up this way, gunna try free off a turn maybe 2 and get it greased over night. Mind im the king of shearing bolts at work. Sheared a 21mm wheel bolt with my 600mm bar coz the gaffa said get it FT (fkn tight) lol . I was new lolYes, they all are. They regularly suffer with galvanic corrosion where the steel bolts passes through the aluminium mount body.
Only this past Friday I had a bolt head shear off due to this reaction.
Once the mount is prised off the stub if bolt left over you can quite often unwind them from the subframe thread by hand.
I've done loads like this over the years.
Hi Connor, im looking at making this fix this week, any chance you have the part number for this shim?Me again. Did the 02M shim mod, what a big difference a little shim can make. Well recommended, my bearing had loads of play in it too.
Looks good, did you make or buy that?Here is glove box trim pic.
