Cupra 290BE Bucket seat white trim cracked!
Peller
600
191
Edinburgh
Looks similar to all guys' problem in this thread, only in your case the white path "was stronger" a bit.
I guess (if you look for previous messages) - it is because of the shape of the seat, when you get in to the car - before you sit straight in the seat - first you seat partially on the side of the seat, where's the crack usually happens.
This. My 2018 Cupra with the replacement Carbon effect pleather is starting to wear. I can't help but flattening it every time I get in and out of the car.
I've raised the seat up to try and make it easier but it's hard due to the low natural seat position. I'm sure it's only a matter of time before we get the same issue.
Sent from my moto g(7) power using Tapatalk
FOX1429
103
15
Wales
Same here 2018 Cupra bought with only 2000 miles on clock (now 5000) starting to do the same ??
