Manic172
- How very careless of you - You are on detention - Report to the headmistress at 3pm sharp !!
This could be interesting
shes docking you 25Bhp instead.
You are very lucky !! Headmistress is too tired after a night with 3 choir boys and a a blow up toy - shes docking you 25Bhp instead.
My hero
can i pls buy the front right cover?
Ill pm you buddyYou may make me a offer I will take it off the car when it comes off the ramp in a bit and I will try get the string as well
I will get pictures too
Ill pm you buddy
love your knob mateGot a fancy Seat Sport Carbon shift knob and a nice little shifter boot haha . Don’t like the blue though
Just Incase as I’ve emailed you back, i will have 3D printed in black ABS jacking point covers going up for sale next week from the website.
Also Connor, about your pressure drop I also had this issue and solved it by replacing my old PCV valve and recirc valve.
Also a good place to check is the MAP sensor! As it is what measures the air going into the engine after the intercooler
boost leak code came back, so patiently waiting for some last bits to arrive for my fmic kit and then im cracking on.
Ruled out a leaking DV at least, forge one back on.
You got a boost gauge? What’s your vac at idle? Should be around 20inhg or .6bar vac
If the issue persists after i fit my fmic i will start a thread for it
Okay so good news is that you don’t have a vac leak. I would really suggest swapping the MAP sensor. As it sits right before the throttle bottle after the intercooler. (It measures the „manifold absolute pressure“) so if you’re getting a pressure drop fault code between charger and throttle body this could be of help.
You don’t have a tube right? Stock mapping?
I went with original Bosch. For mine it was part number 0 281 002 177 here is a pic of the old one. Be sure to look at yours and get the part number off of it. As they had 2 different sized ones. (Diameter of the Sensor)
I got mine of amazon for 40€ and arrived next day.
Also it would be pretty easy to find a leak in your stock intercooler piping. As there would be oil coming out of the crack into the outer surface. Mine had a small boost leak where the metal pipe attaches behind the engine to the rubber hose using a dinky big spring C clip. When these don’t sit right they leak ever so slightly. But if it leaked, you wouldn’t be getting decent boost.
Do yourself a favor and run your boost gauge line directly to the port on top of throttle body or under intake manifold. Then you’re reading the exact pressure the engine sees after the intercooler. IMHO reading from the Turbo area can lead to false readings if there is a problem with the car.
Stock map for me peaks 12-13psi and settles 9-10psi but I’m running a higher flowing exhaust manifold so it could bring those numbers up a bit.
Hope this helps buddy and I hope you find the problem
