8 inch screen swap compatibility?
Sep 22, 2019
7
Netherlands
Hi guys i am currently trying to retrofit my old mib1 for a mib2 with a new 8 inch screen. I found someone who can remove cp and code the rest for a good price.
I bought a MIB2 Std with navigation, part number 5QA035858B (SW 0472 & H41), i also bought the 8 inch screen, part number 5F0919606. I was wondering if the screen and unit are compatible with each other.
Sep 22, 2019
7
Netherlands
8 inch screen will definitely work with mib2
i read somewhere that you need at least SW 0351. There are some units around (for example H24) that are only able to run at SW 0253, that is why i am confused because i also bought another MIB2 unit that is H24 (HW) and SW 0241) before i bought the H41
SteveGSXR600K1
588
193
That's correct, it does have to be at least SW 0351. Something to do with the resolution, I think.
wolverine_uk
70
I would assume that would be newer than 0351. When do you plan on fitting it?
wolverine_uk
70
The screen is pretty easy, little bit of cutting down to do. What size screen do you currently have? I went from 6.5 to 8 bit didn't have to change my MIB unit
Sep 22, 2019
7
Netherlands
i still have the old mib1 so this is going to be a big step up with android auto and such
