Nope all the radio stations are fine for me (that I know of).
Sent from my Pixel 2 XL using Tapatalk
It's changing the FEC codes to a higher order I want... if you can do that with ODIS for free I'd be interested. They made a bit of a mess with the adjustments to the FEC codes and the map update since it messed up the traffic sign recognition which then got set of triggering speeds at KPH and not MPH. If you get a backend map update in which isn't valid against the navigation FEC update limit then it doesn't work since it's not valid against the allowed navigation FEC it does behave like this (may be a repeat in there), so I suspect that writing the FECs after it's inherited this behaviour means you are stuck. Possibly should have gone back to a working map before changing the FCEs. I was stuck in Doncaster waiting for them to come up with a solution. Slovenia / UK conversations they had and thought. They then said they restored my original settings which fixed it .
I think the FECs are protected by the primary key if it's like the rest, so unless you side step the key then you can't do much with them outside of what you are suppose to do. I spent 18 months experimenting with Mib2 high map updates and concluded it was beyond me so deferred it to a retrofitter. It's a dark art. I did manage to get a dark art specialist coming up on the Leon navigation thread, Chillout and he hadn't done it yet but I know he had wrecked his system in the past... so put that on hold. OK for 7.5 years. Chillout performance dials and so forth that Walone wanted. He's the author of those. Custom addons to the MIB2 High. I can pass on those on my 190TDI 4Drive Ateca .
https://www.facebook.com/mqbcoding/...-and-gentlemenhere-we-proud/2528744587185417/
I'll look at in 7.5 years or when it stops working. . I just sat in the drive or took many test drives around Doncaster with the TSR issue and drank coffee till they sorted it out. Checked out Holiday Inn Expresses. I was offered 1409 but turned it down just wanted the Mapcare restriction lifted.
Wonder where Walone is. I'm on 1376 that they put me on a year ago with the Fec edits in November when the map update limits re hit after getting "unlimited" the year before. Walone I believe is now on 1409... but hasnt revealed his FEC. I used the personal touch .
Did you update your firmware after the FeC edits? The patch is then removed and needs to be applied again.
Do you have the older firmware available? Maybe you could help me with my update
I have sent you a link in our 'Conversations'I have a MIB2 High with 0319. I want to update to 1376 and then to 1409. I have both firmware updates, but i need to update first to 06xx and 08xx and then 12xx before i can install the last two updates.
Can somebody help me with the older versions?
Hi Tell, I still haven't got round to investigating my system update properly but I think i'm not goingI hope they make good reading .
Are you saying that a Seat service depot/centre did an update on the head unit, if they did then they are liable unless the unit had been modified previously.Hi All! A friend of me have a strange problem. He has H42 SW0319, and the service had something set on the head unit, and now he has no bluetooth, no USB, and the Mode button not goes... He went back, but the service can do nothing... Do you have any idea? As i know, for this HW there are some newer SW, example: 674, 818... etc. but i have SWs only for the H24 unit... Could someone help me? Thanks a lot!
I had quite a few errors when I got the unit back, Nav database and SVM amongst others, cleared the SVM with the usual method and deleted all the DTC's but some came back after driving the car, then I cleared DTC's again and they stayed clear but I have not checked since.Presume it's not giving you navigation database errors now ?. I've been clear of them - result of time being up on the Mapcare FeC. They left me with SVMs but I decided I would not attempt to remove them this time. In reality nobody cares about SVMs.
The FeCs (firmware enabling codes) are really parameter files that are read in to make the software behave in certain fashion. The firmware loaded up is the original.
It's in 5F Adaptations I think, do an ADmap first.As my friend says, they made a factory reset or something like that... (he didn't see) and after than, the Mode button not goes, the BT, and the USB... Thank you for your answer! I have VCDS, maybe i look a save from a simillar car, and try to re-enable the things...
