lightup
324
275
So wrong lacquer fcks your live up. its even a bigger mess as what i started with.
Will see how this will go....
Anyway i did fit my refurbished black coated lcr wheels to finish the look. And lcr tip exhaust
Verstuurd vanaf mijn SM-G960F met Tapatalk
Reactions: bigT's lcr
iammooks
1,814
1,220
Booked in for my MoT today - 4pm next Tuesday should give me a chance to give it a good run before the test. If it passes without any trouble I'm probably going to go ahead with changing the clutch myself, so expect plenty of stupid questions from me about why there are four Sachs clutch kits on the eurocarparts website and they're all different prices but have the same measurements...
Leon20vt4
939
683
Broke down yesterday. My clutch pedal broke & fell to the floor :( Managed to coast out of rush hour traffic in neutral & rac came to rescue. Must be the month for clutch issues!
Sounds like either slave cylinder valve or centrifugal clutch cylinder
Sent from my Note_7P using Tapatalk
Leon20vt4
939
683
**** must've been a mix of two types of paints... Never mix enamel, lacquer, or acrylic paints always stick to one type.
best thing might be to bathe in some kind of paint thinner depending on the paint you used. But be careful as some paint thinners can damage plastic.
Alexis27
2,188
515
Manchester
Try https://www.clutchstop.co.uk
Reactions: iammooks
Connor H
1,037
511
Essex
That’s brutal! Reminds me I need some 2k lacquer with a hardener mixed in. Anyone got any recommendations where to buy?
iammooks
1,814
1,220
Thanks for this - still confused, but it's probably safer to say I'm less confused than I was before.
The main thing for me is making sure I have all the things I'm going to need before I start dismantling the car - but the more I read about clutches, the more I'm starting to feel like that's actually part of the challenge - you might need a new flywheel on this job, a new master cylinder on that job, a new release bearing on that one...
