Brake tool arrived this morning - with all the right parts this time.
And it's raining.
And it's raining.
Got some winterwheels.
Verstuurd vanaf mijn SM-G960F met Tapatalk
Fitted new gear knob leather to it from my old Leon I stripped out, took door panel of to find I do need a new driver windows regulator and the rear shock are both gone.
Mine went wonky but miraculously fixed itself a couple of weeks later.
Ive been told the rear light clusters leak. Im checking mine next week but have a sneaky suspition my leaks co.ing from the sciluttle pan when i fit the boost gaugeOke so i got a waterproblem in the rear of my black topsport(cupra) Completly soaked im the back while my doorseals are kitted and dry. Is there any other way water comes in? I dont get it.
boot is dry, its behind the passenger seat.
Today I tackled a long term diesel leak. That spaghetti of braided pipes at the back of the engine bay was all wet so we started by replacing all those, thought we'd change the diesel filter while we're at it and hey why not the air filter and oil and filter too. Started cranking her over to bleed, all going well, seemed to take a while longer than usual though. Then she fired, sounded so lovely ... then OH waves like a demented thing from under the bonnet to cut cut cut ... what's the matter? Diesel spraying everywhere. Did I leave a pipe off? No, seems injector 2 has worked itself loose. Yes you read that right, injector, loose. About an eighth of a turn loose, too.
Anyone ever heard of an injector working itself loose? I thought those little beggars liked to weld themselves in until they had more chance of snapping off than ever giving up their burrows. I've had the car 3 years and they've not been touched in that time.
I always thought they both did ... am I wrong?Are you talking about the injectors or the glow plugs that weld themselves in ??
