Is it possible to pair the key with OBDelevent?
Hey guys,
Just bought a 2015 Leon FR this week.
I want to use the second key as my main key. However, the fob doesn't lock / unlock the car, nor it manages to start the engine. When I try to start the engine it stays "Immobilizer active". The key has new battery and the light lights up well when a button is pressed.
I also tried a lot of different combinations found on the internet for synchronizing the key (and also the method I found in the user manual), unfortunately with no success.
Thanks in advance.
Yeah. I tried quite a lot of combinations, unfortunately none of them worked, but it is good to double check.Have you tried this and I presume that the primary key works fully.
Most VAG vehicles use "switchblade" keys and key fobs. The process for programming these remotes is the same, no matter what Volkswagen model you have. You must have at least one programmed key fob to program another one to your Volkswagen; if you don't, visit your local dealer for options.
Step 1
Insert the key you want to program into the ignition. Turn it to the "On" position, but do not crank the engine.
Step 2
Step out of your Volkswagen and close the driver's door. Insert your primary key into the door lock; turn it to the right to manually lock the door. Remove the key.
Step 3
Press the "Unlock" button on the key fob. Wait one second, and then press the "Unlock" button again.
Turn the ignition off and remove the key. The key fob will now be programmed to the vehicle.
Tip
Items you will need
- Your Volkswagen vehicle stores up to four remotes in its memory. If you are programming a third remote, you'll need to press "Unlock" three times, rather than two times. If you are programming a fourth key fob, you'll need to press "Unlock" four times.
- Primary key
Just a heads up for those who dont follow the beta testing on OBD11 Forum,
Next OBD11 Release
- Added Workshop number Setting
- Added EEPROM function (Go to Control Unit -> EEPROM)
- Added Full Backup (Go to Vehicle -> Backup)
- Extended Backup functionality
- Improved Apps to show newly added Apps
- Improved Charts to support 16 values
- Moved Charts access from Live Data to Control Unit
Full Backup and increased number of values for charts will be helpful
@LouG this is what i was referring toFollowing on from a thread the other day where @Damo H was talking about engine temps.
The analogue dials on my car go from zero to 90 very quickly and just stay there never move.
Looking through Live Data on OBD11 And i noticed a value called Coolant Temperature, this shows a much better value and does fluctuate so gives a better idea of what is going on.
I also discovered (and this I had not seen before) Oil Fill Level which appears to show how much oil is in the sump there are also values for min and max. I did some recording and the oil level changed a bit as I was throwing car round the corning or accelerating hard so another one I will add to my regular watches.
Oooo didn’t realise you could set it so the mirror didn’t fold out on unlock. I’m assuming that’s on engine start. My Mk2 was like that. @paddy6789 I feel a visit coming haha1 - Module 09- Electronic control unit. Code (31347)
2 - Adaptation
3 - Access control 2 Up to MY16 or enter Spiegelverstellung From MY17 and later
4 - Funk spiegelanklppung modus - (Change value to Convenience operation via remote control key)
Press and hold the button to fold or unfold
5 - Funk Spiegelanklappen - (Change value to On)
If you also want to close with a single click instead of keeping the button pressed:
6 - Funk spiegelaklappung modus - (Change value to By look command via remote control key)
If you also want to appear in the car menu to activate or deactivate from the screen:
7 - Menuesteuerung funk spiegel anklappen - (Change value to On)
If you also want the mirrors do not open whenever you open the car with the command and only do so when contacting. (Only in vehicles whose "42 and 52" door units whose software version is: 0032. In previous ones the control units must be updated)
8 - In Adaptation, enter Spiegelverstellung
9 - Signalisierung_Spiegelanklappung - (Change value to Deactivated)
It works both if we have done the closing mod with a touch, as if we have not done it.
Read more: http://forum.obdeleven.com/thread/6342/adaptions-spanish-site#ixzz62SdpJuUP
this is what i have
I have a MY2018 and I have my mirrors set up as follows....Oooo didn’t realise you could set it so the mirror didn’t fold out on unlock. I’m assuming that’s on engine start. My Mk2 was like that. @paddy6789 I feel a visit coming haha
Did you get this sorted?Any ideas how I can this screen on my MIB2 high? Is it under skins or version? Or not even possible? 66 plate cupra 290.
How to add more skins?Did you get this sorted?
I did it via the Developer Menu....
SERVICE MODE/Test Mode/HMI Skin Change/SEAT_STD_SKIN_SPORT_80_S
though I have an MY2018 facelift
