lightup
324
275
If you’re wanting to do steering wheel refurbishment at home this kit cost me 20 quid from amazon.
Was very easy too.
Badger5 Custom Map + TIP,
looks good too. but im a guy. i suck with needle and threat.
Leon20vt4
939
683
Well, there you have it. Everyone I've heard of who's done it has said it worked wonders, so I'll have to look into it. Magic Tree just doesn't cut it anymore...
Put it this way... I spilled 18 year old gearbox oil in the trunk while transporting the old transmission.
I bought the car and it had mold on the seat covers and smelled like mold. As well as a smokers car...
Now all of those smells are gone. And the car smells so great and neutral! Not like a new car and not like an abused car just totally clean smelling hard to explain.
Clean entire car first...
Best thing to do is have the air running on recirculation mode and pop in new cabin filters while you’re at it!
Run the ozone generator for 1 hour then open all the doors and walk away for 20-30 min leaving the air running too.
Then you’re good to go.
Inhaling ozone O^3 takes away the oxygen O^2 and can cause hypoxia if exposed too long. (Lack of oxygen to brain) it can also cause harm to your respiratory system, so best to just hold your breath and walk away.
I’ve done it a few times now and have had 0 issues it works wonders! Just don’t be stupid.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Tell me more! the one I have ins't as bad as yours but is quite bad.
Ill try and find the kit itself and take a photo.
You get sand paper to rough up the leather. Then a binding agent to fill and put back a bit of youth. Then I think a colour dye and then a sealing agent.
Took an hr or so.
Sent from my iPad using Tapatalk Pro
Leon20vt4
939
683
So found out a few things.
Denmark indeed has a DRL law where all cars need daytime running lights. So it was never a switch problem.
I found a pin out description decoding the light switch. I disconnected the TFL pin number 3 and it worked like a charm no more low beams on while 0 is selected on the light control switch! Thank god!
iammooks
1,801
1,197
I love the last bit - "just don't be stupid"!
I'll have to look into it - what little research I've done either brings up generators that are very expensive, or very cheap, or people who will come to you and do it for you, but who don't post clear pricing on their website or make it sound like it's going to cost hundreds.
At the moment it smells like someone's been living in there. Someone with really bad flatulence...
Leon20vt4
939
683
I’ve had both the cheap ones and the 100€ ones... the cheap are the same as the expensive ones just the expensive ones have a timer and a housing around it... but inside it’s exactly the same!
Reactions: iammooks
