Is it doing a deal for the toledo rear arches for the build... So it's rear should look some thing like like View attachment 10263
Still unsure on spoiler. May go for supercopa but have a little play with wing ends. Or seams as it's a wide body type race car build I might go for the byc wing.... I need someone who is good on designing stuff and putting pictures together to how stuff looks
They look aceI am doing a deal for the toledo rear arches for the build... So it's rear should look some thing like like View attachment 10263
I may have one rubber door trim left.
Just checked the nappies - it's gone from swamp to bone dry overnight! They must have soaked up at least two litres. Get 6+ size - the biggest and most absorbant.
That's an odd one if you've already replaced the headlight switch as I've seen this happen with faulty switches.
I've just noticed that your dashboard is different to usual and has a dimpled texture, is that from an A3 8L?
the grey part? i swapped it for black dash. top dash is same as my cupra i reckon.No it’s the stock Leon dash. But it could be that it’s a 4x4 thing? I don’t know for sure. Maybe @lightup can confirm if his 4x4 is the same way.
