INSTRUMENT PANEL
29)
Virtual Cockpit Sport [WORKING]
1. Control Unit 17 (Dashboard)
2. Adaptation
3. Sport
4. Change the value to "Display" [Standard: "Don't Display"]
30)
Stopwatch [WORKING]
Enable the stopwatch in the instrument panel. It also works with the Virtual Cockpit.
2. Long
Coding
3. Lap Counter: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 3
31)
Hand test at startup [WORKING]
Only works with the analogue tachometer.
2. Long
coding
3. Staging: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 0
32)
Backlight for day / night instrument panel (display and hands) [WORKING]
2. Adaptation
3. dimming_characteristic_curve_adjustment_clock_dial _day (Day)
Y1: change the value to "3" (Maximum) [Standard: "0"]
Y2: change the value to "5" (High) [Standard: "0"]
Y3: change the value to "8" (Average) [Standard: "0"]
Y4: change the value to "8" (Low) [Standard: "5"]
4. dimming_characteristic_curve_adjustment_clock_dial_night (Night)
Y1: change the value to "5" (Maximum) [Standard: "2"]
Y2: change the value to "6" (High) [Standard: "2"]
Y3: change the value to "E" (Average) [Standard: "0E"]
Y4: change the value to "1E" (Low) [Standard: "1E"]
33)
Missing tank liters [WORKING]
The same
coding can be obtained by spending 10 credits
2. Long
Coding
3. Byte 10
4. Enable Bit 4
34)
Compass at the bottom [NOT TESTED]
Move the compass icon to the same temperature level.
2. Long
Coding
3. Byte 09
4. Enable Bit 3 and 6
OTHER
35)
Disable Start / Stop [WORKING]
1. Control Unit 19 (Gateway)
2. Adaptation
3. Start / stop start voltage limit: change the value to "12V" [Standard: "7.6V"]
36)
Fan speed in automatic mode (Climatronic bi zone) [WORKING]
1. Control Unit 08 (Air Condition)
2. Long
Coding
3. Blower display in auto operation: change the value to "Activated" [Standard: "Not activated"]
37)
Mirror closing 1 click [NOT TESTED]
It allows the mirrors to be closed without holding down the machine closing button, for cars equipped with electric mirrors.
1. Control Unit 09 (Central Electrics)
2. Adaptation
3. Spiegelverstellung
4. Funk_Spiegelanklappung_Modus: change the value to "by_look_command_via_remote_control_key" [Standard: "by_convenience_operation_via_remote_control_key"]
38)
Accelerator response [WORKING]
1. Control Unit 44 (Steering Assistance) Code: 19249
2. Adaptation
3. Driving profile switchover:
to. "Incremental, controlled over time" (Standard)
b. "Direct, controlled over threshold"
39)
Steering response [WORKING]
2. Adaptation
3. Characteristic curve of steering assistance:
to. "Driving profile selection button" (Standard)
b. "Comfort"
c. "Automatic"
d. "Dynamic"
is. "Default"
40)
Switch-on driving profile [WORKING]
2. Extended
Coding
3. Byte 8 (E8)
4. Activate Bit 4
(After this change, Byte 8 will change from "E8" to "F8")
41)
Battery [NOT TESTED]
Useful to change the values if the standard battery is changed.
2. Adaptation
3. Battery Adaption
4. Change the values to those indicated on the new battery. (Ah, Manufacturer, Serial Numer and Technology)
42)
Hill Start Assist Sensitivity [hill start car] [NOT TESTED]
1. Control Unit 03 (Brake)
2. Adaptation
3. Hill-start assistant
4. Hill-start assistant: change the value to:
to. "Normal" [Standard]
b. "Early"
c. "Late"
