Ghost45
OBDeleven encodings
Ghost45
61
22
Rome
Guide now located in the new resources section of the site
Ghost45
61
22
Rome
You must consider that these codes are for more cars... Probably in this car is not soprt but dynamic.
I do not have virtual cockpit this code is tested so is ok... but you must see if this 'parameter' is come out... Inside.
Reactions: IbizaSRB
Aroza
10
OEM alarm (Horn) [WORKING]
Enables the standard alarm that makes the horn sound, for those who did not purchase the volumetric burglar alarm with an audible alarm, proposed as an option, during the purchase phase. NOTE: with this code the automatic closing of the mirrors when the vehicle is closed will be disabled
1. Control Unit 09 (Central Electrics)
2. Adaptation
3. Diebstahlschutz
3a. anti_theft_alarm_system: change the value to "Active" [Standard: "not active"]
3b. Akustischer_Alarm_Signalhorn: change the value to "Active" [Standard: "not active"]
3c. DWA_Alarmverzoegerung: change the value to "delay_driver_door_contact_thatcham" [Standard: "delay_driver_door_lock_cylinder_skoda"]
3d. Diebstahlschutz_mit_Anhaenger: change the value to "Active" [Standard: "not active"]
First of all, thank you very much for sharing all this usefull information!
About the OEM alarm tweek.
How can I test it, to see if it works?
Aroza
10
Offroad Menu [WORKING]
Adds the Offroad menu (Wheel angle, oil temperature, etc.). It works even if you don't have the navigator, with some limitations. Touch the machine symbol> Visual> Offroad. In the absence of the standard navigator, the app will report an error as it cannot find components related to the navigator.
1. Control Unit 5F (Information Control Unit)
2. Adaptation
3. Car_Function_Adaptations_Gen2
3a. menu_display_compass: change the value to "activated" [Standard: "Not activated"]
3b. menu_display_compass_over_therhold_high: change the value to "activated" [Standard: "Not activated"]
3c. menu_display_angle_of_slope: change the value to "activated" [Standard: "Not activated"]
3d. menu_display_angle_of_slope_over_threshold_high: change the value to "activated" [Standard: "Not activated"]
4. Car_Function_List_Bap_Gen2
4a. compass_0x15: change the value to "activated" [Standard: "Not activated"]
4b. compass_0x15_msg_bus: change the value to "Comfort data bus"
4c. angle_of_slope_0x24: change the value to "activated" [Standard: "Not activated"]
4d. angle_of_slope_0x24_msg_bus: change the value on "Comfort data bus"
5. Long Coding
5a. byte_24_Navigation_System: change the value to "activated" [Standard: "Not activated"]
I also tried the off road menu
At first it seemed to be working but very quickly it started freezing up until the screen was blank.
See the pictures below.
Ghost45
61
22
Rome
Hi Aroza,
Yes i have seen this rallenty in my ibiza too.
But i do not change the color to green.. So try probably to turn back to red color and reset... With turn off the button of the radio for few seconds and see if the rallenty is on again...
Reactions: Aroza
Aroza
10
Hi Aroza,
I own an Arona myself.
I didn't change the color to green!
And what does "rallenty" mean exactly? :)
I was thinking of reseting, but I dindn't want to lose all the radio stations. But I will try it...
Thanks again!
Mille grazie!!
Ghost45
61
22
Rome
@Aroza,
ohh yes probably the Arona have the green menu' insteat of red in our ibiza!
I mean slowdown in several menu' like the black fiber i have seen this slowdown...i don't know how!!!
About the reset is to apply the modify after coding....but not will do any delete of radio station!
Reactions: Aroza
at0ny
155
33
Holland
INSTRUMENT PANEL
29)
Virtual Cockpit Sport [WORKING]
1. Control Unit 17 (Dashboard)
2. Adaptation
3. Sport
4. Change the value to "Display" [Standard: "Don't Display"]
30)
Stopwatch [WORKING
Enable the stopwatch in the instrument panel. It also works with the Virtual Cockpit.
2. Long Coding
3. Lap Counter: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 3
31)
Hand test at startup [WORKING]
Only works with the analogue tachometer.
2. Long coding
3. Staging: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 0
32)
Backlight for day / night instrument panel (display and hands) [WORKING]
2. Adaptation
3. dimming_characteristic_curve_adjustment_clock_dial _day (Day)
Y1: change the value to "3" (Maximum) [Standard: "0"]
Y2: change the value to "5" (High) [Standard: "0"]
Y3: change the value to "8" (Average) [Standard: "0"]
Y4: change the value to "8" (Low) [Standard: "5"]
4. dimming_characteristic_curve_adjustment_clock_dial_night (Night)
Y1: change the value to "5" (Maximum) [Standard: "2"]
Y2: change the value to "6" (High) [Standard: "2"]
Y3: change the value to "E" (Average) [Standard: "0E"]
Y4: change the value to "1E" (Low) [Standard: "1E"]
33)
Missing tank liters [WORKING]
The same coding can be obtained by spending 10 credits
2. Long Coding
3. Byte 10
4. Enable Bit 4
34)
Compass at the bottom [NOT TESTED]
Move the compass icon to the same temperature level.
2. Long Coding
3. Byte 09
4. Enable Bit 3 and 6
OTHER
35)
Disable Start / Stop [WORKING]
1. Control Unit 19 (Gateway)
2. Adaptation
3. Start / stop start voltage limit: change the value to "12V" [Standard: "7.6V"]
36)
Fan speed in automatic mode (Climatronic bi zone) [WORKING]
1. Control Unit 08 (Air Condition)
2. Long Coding
3. Blower display in auto operation: change the value to "Activated" [Standard: "Not activated"]
37)
Mirror closing 1 click [NOT TESTED]
It allows the mirrors to be closed without holding down the machine closing button, for cars equipped with electric mirrors.
2. Adaptation
3. Spiegelverstellung
4. Funk_Spiegelanklappung_Modus: change the value to "by_look_command_via_remote_control_key" [Standard: "by_convenience_operation_via_remote_control_key"]
38)
Accelerator response [WORKING]
1. Control Unit 44 (Steering Assistance) Code: 19249
2. Adaptation
3. Driving profile switchover:
to. "Incremental, controlled over time" (Standard)
b. "Direct, controlled over threshold"
39)
Steering response [WORKING]
2. Adaptation
3. Characteristic curve of steering assistance:
to. "Driving profile selection button" (Standard)
b. "Comfort"
c. "Automatic"
d. "Dynamic"
is. "Default"
40)
Switch-on driving profile [WORKING]
2. Extended Coding
3. Byte 8 (E8)
4. Activate Bit 4
(After this change, Byte 8 will change from "E8" to "F8")
41)
Battery [NOT TESTED]
Useful to change the values if the standard battery is changed.
2. Adaptation
3. Battery Adaption
4. Change the values to those indicated on the new battery. (Ah, Manufacturer, Serial Numer and Technology)
42)
Hill Start Assist Sensitivity [hill start car] [NOT TESTED]
1. Control Unit 03 (Brake)
2. Adaptation
3. Hill-start assistant
4. Hill-start assistant: change the value to:
to. "Normal" [Standard]
b. "Early"
c. "Late"
Sport mode tested on 4 cars with VC in Holland. None of the ibiza's (2018/2019 and arona(2019) Worked. Only worked on the leon 5F facelift with VC...
Verstuurd vanaf mijn SM-G965F met Tapatalk
Aroza
10
@Aroza,
This is what it looks like now.
About the question I asked you regarding the OEM alarm tweek.
How did you test it, to see if it works?
Deleted member 103408
Not sure if this has changed but on the prefacelift cars if you turned on the alarm there are no internal sensors so all it checks are
DOORS, BONNET AND BOOT,
Thus you sit in the car and use the key to lock the car, wait for 30 seconds and then open the door from inside using the handle.
Or open the bonnet (which is not possible on the Leon) again after the 30 seconds
Reactions: IbizaSRB and Aroza
Ghost45
61
22
Rome
In our forum this codes of alarm is tested.. But not from me... So i will try.. But of course without the sensors possible that i do not received nothing..
@at0ny,
I will ask in our forum.. I don't have virtual cockpit...
Reactions: at0ny and Aroza
at0ny
155
33
Holland
@at0ny,
I coded a lot of ibiza 6F with VC but sportmode did not work only on the leon facelift.
Reactions: Ghost45
Ghost45
61
22
Rome
Thanks for your testing!
Updated the first page...
So seems you have experience about encodings, is true?
I would like to know.. Do have you experiences about errors in codings or if have you seen some errors in OBDeleven?
at0ny
155
33
Holland
Yes. With vcds and vcp. Vagcomdordrecht you can find me on Facebook, Instagram and internet.
Ghost45
61
22
Rome
Sorry at0ny, but i do not have Facebook... I have discovered these errors and i cant able to resolve them...
I have these types of errors and i can't understand which errors are!!
B131FF2 - Rear window regulator, driver side not coded
Passive
B131FF6 - Rear window regulator, driver side invalid data record
Active
B132054 - Rear window regulator, front passenger side No basic setting
Active
B1320F2 - Rear window regulator, front passenger side not coded
Passive
B1320F6 - Rear window regulator, front passenger side invalid data record
Active
First of all i don't have made no changes or coding about the windows.. But I have seen that in my ibiza that if i close my car with the wireless remote control and push the buttons in closing or turning on pressed my windows do not move at all to the contrary many months ago the windows worked correctly...
What do you think about these errors?
Have you seen these errors codes during your experiences of encodings cars?
at0ny
155
33
Holland
Passive
Active
Active
Passive
Active
Fault no basic setting, is most comon fault. Just press window button down(hold 10 sec) then button up to close window(hold 10 sec) then the window "knows" the basic settings.
How many windows are working? 2x front? 2x rear? Not coded means your bcm dont know if the car has powerwindows. It look like the coding is gone, or there is a problem with wirering. Of there is a problem with wirering, you can check this with vcds and do some output tests.
And also dit you do some coding etc? For example activating auto lock functions, comfort closing functions etc?
Reactions: Ghost45
Ghost45
61
22
Rome
No at0ny, no! I don't have made nothing about the windows...
I have 4 windows electrical... But run correctly or Almost seems....
I do not have vcds...
I entered also in a specific menù to test them..in OBDeleven.. And it make a test up and down but the error are remaining...
