I've seen a couple of posts about removing the 'snow grate' from the airbox, adding a K&N filter and modifying the air intake that runs on top of the radiator. I've done the first two and decided to give the third one a whirl...
This is the stock piece. The bit on the right is what we're going to open up. It sits right in front of the airbox.
Drilled holes in the corners...
Cut and ground it away with a Dremmel.
I smoothed out everything on the left too, sanded it down, and de-burred with a sharp chisel.
You need to lift this up and out of the way when re-installing.
