It is a SWaP festure - means it needs an activation code and only the dealer can do it.
Any ideas how much Dealers charge for this??It is a SWaP festure - means it needs an activation code and only the dealer can do it.
Yeah I've had a boost guage in a vent befor win my old Audi s3 8l. It's fine but looks a bit boy racer as I get older Haha.....And if you are after just the boost you can buy a boost gauge that sits in the air vent or in a pod on your a pillar for £40-00
Ye think so when i lock the car the lights stay on for around 60 s and want then to go out straight away.Are you talking about the coming / Leaving home function then you can turn that off using the cars menu system.
Mine by default is set to 30s but you can turn either one or both off.
Ye it worked for interior lights i should of said i meant headlights etc.Then go to Car Settings and scroll down to lights and then scroll down and you will have Coming home and another line for Leaving Home just adjust the time to 0 and see if that does what you want.
Ill share with you coding for old ABS unit (2013-2014) which doesn't have byte 29 to do coding for ESC Sport/OFF. This unit usually has finished with byte 28 value C0 s TPMS or value 40 without TPMS.
If you want ESC sport/OFF on this unit change coding in byte 25 mark bit 4
After this you will get this setting menu
Thanks for the reply. Does yours think the sidelights are on with the DRL app, and show the door card lights, two LED's, etc? I don't get the point of the handbrake mod to switch the DRL's off.I did the Application on my 2014 Cupra and it works fine, Rear Lights are on all the time except when I pull the Handbrake up (different mod).
