RVC reversing camera installed
Theporter
141
57
Think I might book the eBay one I posted 4 hour round trip but for £279 I cant grumble
SteveGSXR600K1
596
198
This guys have good reputation and use OEM parts (not used them myself) and charge £395 fitted.
http://poollretrofits.com/seat-leon-rear-view-camera/
With SEAT dropping RVC as an option, I suspect companies like this will get more business in future.
The prices they show are a lot more than others, then you read that you still need to add VAT to it! £395 turns into £474.
I wanted to use them to fit front parking sensors, as SEAT dropped them in 2016, but they want nearly £700. I bet they don't sell many of them!
£279 is pretty good. Wonder if they'd do a group price.
Reactions: Theporter
mostafa syaj
17
Middle EAST
HELOO GUYS IM LOOKING FOR INSTALL A REAR CAMERA ON MY OWN LEON 5F SO I MADE CODING FOR INFOTAINMENT SYSTEM AND CHOOSE THE CORRECT BYTE AND TICK BIT 4 BUT AFTER DONE I CHECK THE SCREEN BY PUTTING REVERSE BUT NOTHING SHOW ON HMI DISPLAY ........SO PLEASE I NEED HELP THNX GUYS
Kisszabo
31
Hungary - Győr
Did you connect the cable to the main unit? At the right place?
mostafa syaj
17
Middle EAST
sure friend but first make a test by putting reverse it should be show a message "this function currently not available " so this message doesn't appearance ............ that what i thought .......if the matter is diffrent please notice me
kevster184
686
29
I had to reset the unit, when on hold down the power knob for a few seconds and it re-boots. I beleive I have already mention this on a previous post on this thead.
Reactions: bunziboy
Stefan147
193
140
Athens Greece
Did you order from Carsystems? I ordered from them (RVC high) and here's what they sent me:
Hi
I send you coding information and scheme how connect this set
ADD 6C TO 19
5F ADAPTATION:
CAR FUNCION LIST BAP GEN2-VPS-----ACTIVE
CAR FUNCION LIST GEN2 - VPS msg bus -------TERMINAL 15
Calibration you will have to do yourself if you need it
Best regards
Carsystems Team
Very poor instruction info but I believe I will make it with some help from ELSAwin. What did you use for the coding? VCDS or something else? The above instructions are for VCDS.
Stefan147
193
140
Athens Greece
Please tell your coding options so I can check. Note that i had to buy an original ross tech cable because the chinese one I had could not read the car (2019 Cupra) whatsoever.
