Curious as to how the work so far is holding up, as it's been wet around here the past couple of days.
I'm fighting with a seemingly similar leak, as also shown in one of your photos, the water in mine seems to be becoming visible on the flat spot near where the steering joint goes through the floor, there is a rubber plug in this area. My leak then seems to go under one of the floor-reinforcing panels, and then emerges from one of the seams in the footwell, either nearer the front left corner, or further back under the seat.
I've already silicon'ed the plastic cable box under the windscreen scuttle, so will try the bonnet cable grommet today, if I can dry it out that is.
Anywhere else that might need attention?
Were you able to see where it was getting in in the first place?
Also, the rubber plug near the steering joint, it seems to be plugging a hidden channel, does anyone know where it comes from, and where it emerges?
