LED Fog Lights/White Fog Lights
EFF11
138
39
You can fit LED bulbs in the Seat fog lights but they must be the correct type.
LED fog light bulbs that have LEDs distributed around a cylinder, and also have front facing LEDs are projector bulbs. These are for projector fog lights, in which the front glass is a lens that shapes the beam. If they are fitted to a Leon fog light they will scatter light in all directions.
Leon fog lights have a plain front glass and the beam is shaped by the reflector/halogen bulb combination. The relatively small filament of the bulb is positioned as a single source of light at the focal point of the reflector. This produces a controlled wide beam with a sharp horizontal cutoff. Also, the bulb is capped to prevent uncontrolled light from being projected forward to obliterate the cutoff and dazzle oncoming drivers.
A replacement LED bulb must have an LED, the same size as the bulb filament, attached to each side of a flat blade. The blade must be vertical when installed in the housing and must be capped.
Two reliable brands offering the correct bulbs are Nighteye and Novsight. I fitted Novsight bulbs from Amazon. When I fitted the first one the cutoff aligned correctly with the original bulb in the other fog light. A scan with OBDeleven showed no fault codes. The beam from a fog light should decline from the horizontal by approximately 3 degrees.
The images in the Amazon listing show the structure of the bulb. They are cheaper on Ebay but Amazon is a safer bet because you can return them if you experience any problems. There are very similar bulbs on ebay that are not capped. They are projector bulbs.
https://www.amazon.co.uk/NOVSIGHT-H...8451271&sr=8-1&keywords=novsight+h8+fog+light
Ash82
148
37
Manchester
I’ve just order these, any thoughts?
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/371777157354
EFF11
138
39
They are projector bulbs. Each of the LEDS will create it's own beam off the reflector and the light from the front facing LEDs will be uncontrolled. There is an amusing USA video on Youtube in which a man drives down a highway proudly demonstrating the way his new LED fog lights light up overhead gantries better than his headlights. Not much beam cutoff there.
If you scroll down that listing you will see two Nighteye bulbs that are right for the job (single LED), and cheaper. If you look at the images of the Novsight bulb in the Amazon listing you will see that the LED is the same size as a halogen bulb filament. That is the only way an LED fog light bulb can emulate a halogen bulb.
You are better off buying from Amazon because you can easily return them, especially if one turns out to be dud.
Reactions: LuM and Ash82
Ash82
148
37
Manchester
Hi
Thanks for the reply, I will contact them to send back. I want to get the correct ones for the car.
Have you got any pictures of yours done?
I assume they match well with the led lights?
EFF11
138
39
Hi
I can't post photos, but they are very bright and match the LEDs. It is worth getting the Novsights because we know they are OK. Straight swap, no beam adjustment needed and no errors.
I suspect there are a lot of cars driving around with projector bulbs in their fog lights.
Ash82
148
37
Manchester
I am going to get them, also if they are error free that’s a bonus . I appreciate the assistance
I will try and post some before and after shots
Ash82
148
37
Manchester
Bulbs have arrived
Spuddy01
20
10
Just ordered the novsight bulbs from aliexpress so let the wait begin. But I'm sure it will be worth it once they arrive & for €11.81 delivered can't go wrong
Rif
58
26
Good advice thanks. Am about to order the bulbs in the link. Will they need fettling to fit in the H8 holders?
EFF11
138
39
No, they are already mounted in bulb holders as are the halogen bulbs. Just remove the existing bulb from the housing and disconnect it from the wiring harness. Then connect the new bulb to the harness and install it.
They are a very bright white light with a slight bluish tinge (colour temperature 6000K, power 80W). That is the same for any LED fog light bulb you will see on Ebay.
Rif
58
26
I thought the H8 and H11 bulb holders had slightly different tabs. Thats why I was slightly confused by the item description which lists every type in the title. I guess they have made a universal holder type which accommodates all tabs?
Wastedagen
481
101
Milton keynes
Nope, I put H11 LEDS in my fogs as opposed to oem H8 . No issues at all.
Rif
58
26
Came across this company intro vid on Novsight
Also an explanation video which illustrates the points EF11 was making.
Reactions: Spuddy01
EFF11
138
39
Just noticed that the Amazon listing has changed from 'Sold by Novsight fulfilled by Amazon' to 'Sold by Novsight', and the price has increased to £21.98. So you wait a few weeks for them.
You can get them direct from Novsight for £16.84 and pay by Paypal.
https://www.novsights.com/collectio...ght-fog-light-1700-1800lm-pair850-900lm-bulb#
Sorry
Just noticed the bulb in this listing is identical to the bulb I bought but the listing does not include H8 as a compatible size. But it does include H11 as the Amazon listing does. So they may not fit.
Ash82
148
37
Manchester
Reactions: Spuddy01
Spuddy01
20
10
Upgrade mine now , they look brill I will take a picture in the dark. Getting around the water tank was a problem , I had the remove the arch casing but I was taking off my winter tyres anyway
Looks like a bit of work involved would you say it's easier to remove the wheels to get the bulbs in?
