Before I have my first go at stuff. Do I make an overall back up or is it just in the specific section? I want to do the carbon backgrounds and 1 click mirrors.
I've done a control unit backup. Is that right?I would always recommend full backup simply because you might forget the others later.
But if you dont have the patience for that then just do the ones you are going to work on.
App does have history but I much prefer the backup.
I think after I've done one I'll understand but I don't even know what the module is?
Hello.
If you have factory warranty, make these changes, will not affect it? I ask this because I read in an Audi forum that the owner changed some things on his A4 and the dealer canceled his warranty by connecting another computer / device (other than theirs) in the car's central station.
Warranty is a very grey area. My personal understanding (and i am well out of warranty) is that if you wanted to buy an extended warranty they may refuse if they see you have modified the car. With regards to making a warranty claim if you are claiming for a new rear light (because its cracked) or a new gearbox because its broken they would find it very very difficult to claim you had caused that using one of these tools.
However if you changes the dashboard settings and it failed they may (and what i have seen its only when people tell them they used VCDS/OBD11/CARISTA) refuse this work. I also see much more feedback on these issue in the USA vs Europe (not to say it does not happen but a lot less noise about it)
I would be astonished if anyone at the dealer will ask..... I have changed settings with vcds on the last five new VAG cars we have bought. There heave been some warranty matters. No one have mentioned anything about my own “change of settings”.
However if you end up with problem caused by you change, that will be a different situation.
/Peter
I had a quick watch and I've successfully managed one click mirrors and carbon background for FIS and the infotainment thanks
So to recap I've done:
1 click mirrors
Carbon backgrounds
Lock chirp
Needle sweep
Lap time
Refuel amount
Driving school
Not sure what else I can do
I just do not risk it because some of the changes I like to make will be very visible (for example, changing the background of the on-board computer), so do not risk
do them so that they have no possibility to complain and say that I have been changing things.
Other things you could try are tear drop wipe, increase lane change blinker count (or whatever its called ha), change throttle response, remove door open alarm and add drl settings to menu to name a few I have done. Also used obdeleven to help update infotainment software to run later tile version rather than carousel but not sure if that's something your interested in / need as unsure on model of Infotainment you have. Heres a link to obdeleven forum thread which lists coding available http://forum.obdeleven.com/thread/764/coding-adaptationsI had a quick watch and I've successfully managed one click mirrors and carbon background for FIS and the infotainment thanks
1 click mirrors
Carbon backgrounds
Lock chirp
Needle sweep
Lap time
Refuel amount
Driving school
