If you're talking hatchback, It has the central silencer removed. If you're talking ST, there is no difference.
The exhaust is all one piece, so easier to get an exhaust place to cut it out
Yeah.All the way from the cat back ?
https://www.golfmk7.com/forums/showthread.php?t=30422Mid box was removed and back box changed. I have a feeling it’s very similar to the golf gti club sport exhaust unfortunately I have no part number for you. But if you know someone good with a welder then you could dissect your current back box like this https://www.cliosport.net/threads/audi-tt-225-progress.615519/
Although for a golf it’s comparable for 280 and 290. Gives you an understanding as to why there’s a difference. https://www.golfmk7.com/forums/showthread.php?t=30422
Just playing devils advocate if I may... If it's a one piece system why do all the various bits have separate part numbers?Yeah.
Edit - you want to see the size of it off an ST!!
The 290 also has a revised ECU to make it sound sportier too, not to mention the extra HP and Torque.I think you have finally answered something that has bugged me for a while.
I've often wondered what the differences are between the 280 and the others apart from the middle silencer as my car has the middle silencer out and the 290 and 300 sound much sportier even on tick over. I've written post before asking but no one seemed to know other than suggesting that the 290 and 300 have a 3 inch system, I don't think they do though?
Off to eBay now to find a 290 back box someone has chopped off
Didn't know they had, I've only ever seen it as one part. Maybe the different part numbers are if they are doing a repairJust playing devils advocate if I may... If it's a one piece system why do all the various bits have separate part numbers?
As far As I know the eco is not tweaked for for sound and it's exactly the same torque ad the Apologies the torque increased on the 300 not the 290.
However without cutting into the a 280 exhaust and 290 exhaust, not going to know if the 'tweaked' exhuast is just a silencer removed, or the internals of the final silencer as well.
Can you get a part number for the Cupra R Exhaust, as I suspect its the same exhaust as the ClubSport.after doing a bit of digging, rear silencer
Golf mk7 gti clubsport exhaust part no is = 5G6 253 609 AN (clubsport s is DD at the end)
Cupra 300/290 part no is = 5F4 253 609 AF
Cupra 280 part no is = 5F4 253 609 K
https://oemvag.es/es/inicio/1958-silenciador-final-doble-salida-leon-cupra-5f4253609af.html
I also did a bit of digging and you can buy the 290 back box from Seat for £537 or from TPS for about £470 all in.
