Question for member who has fitted Bonnet Hydraulic Struts
ADM
23
16
I have done this mod. I bought 2 gas struts from bestpartstore.co.uk
Part no: 140794 Stabilus lift o mat.
240nm eject force (lifts bonnet perfectly)
length is 602.5mm
stroke is 241.5mm
Also need 4 x 10mm steel ball stud bolts M6 which I bought from eBay.
I made a couple of Steel brackets and fitting it all took 20 minutes.
You will need to trim the foam inserts on each side of the bonnet bracket which was easy enough with a scalpel blade so your bonnet will sit flush when shut.
Hope this helps
davidstarkey11
294
100
Newcastle upon Tyne
length is 602.5mm
stroke is 241.5mm
Hope this helps
Genius, saved a small fortune there! I'll give you £50 if you do it for me? :roflmao:
Jim45
316
86
length is 602.5mm
stroke is 241.5mm
Hope this helps
It seems that most of us haven’t cut the foam as it is so low density, the struts soon make there own space and my bonnet sits fliush.
psychobob
88
Near Cardiff
length is 602.5mm
stroke is 241.5mm
Hope this helps
ADM - what dimensions did you use for the brackets?
Reactions: ADM
ADM
23
16
Here you go, hope this helps.
AdamC11
191
Bolton
I have done this mod too.
I ordered from the Russian seller, I had all the parts in the box when I come to fit them.
billman
120
19
Thanks for the info ADM! Can you post a picture of the other side of the gas strut?
paddy6789
1,627
1,080
Preston, Lancs
It’s crazy that the eBay listing for this was like £30 when I bought them, and now they are £80!
zeffania
476
159
The boot struts have shot up too. I bought a pair for £26. It seems they are that price, each now. I guess sellers have cottoned on to us lol. Gits
Reactions: Wastedagen
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
Anyone know of any reason why us Leon owners can't buy the parts from the Golf and fit them? Are we missing the strength in the bonnet?
I can't bring myself to pay £80 for this kit... The Russian seller on eBay is obviously up to speed with the concept of supply and demand
Titchy
519
208
Buckinghamshire
This!
Or can someone with the Russian kit allow us to have the measurements for the gas struts. On the side of the struts should be writing which will give you the extended and unextended length and the amount they can lift in kg?
All that’s needed is the right angle brackets then.
paddy6789
1,627
1,080
Preston, Lancs
This!
This is all that’s on my ones:
Not sure if that helps
