Hi Explorer, i have long time worked on the protection of MIB1 Standard for my Car because i don't have the Mapcare option to update my maps.
I'm really worried about that because i would like to put the last map updates on my car and if i can do that, i'm obliged to buy something like mirrorlink box (to share my phone screen to the screen of my car) or a new hacked MIB2 unit for at least 1300 USD...
As i know after my research, the unit check the MD5 checksum of the map files, only on the maps files (psf files).
All other files of the SD card are not protected, like that, it's possible to change the version of the map on the dbinfo.txt file with no
problem for example.
For me, the only solution is to change de MD5 cheksum of the new maps files to the same of the old maps files but i don't find a software to do that (like change just the end of the file to transform the MD5 result of it)
If you've founded a solution to make it work the map update, even if we have to weld something on the unit, please say us the solution !
We are responsible of what we do ! you will be not affect if somebody makes a mistake with your solution.
But, your are on a Forum and the first work, the first utility of a Forum is to share knowlegde.
So, please, for all the members, for me, share your knowledge !!!!!
Many many thanks for your comprehension.
