Will these fit the ST?
Sent from my XT1068 using Tapatalk
Think the ST tailgate is different, and needs different struts.
These are the exact ones you want, fit great, raise the boot perfectly will fit 3 or 5 door
Hi,
I have found the ones you have suggested, unfortunately has none available to buy atm.
http://www.ebay.co.uk/itm/2X-STABIL...245732&hash=item5684053674:g:hrQAAOSw9uFW8l2Q
When you purchased these which options did you select:
MAKE / MODEL / YEAR / VARIANT / TYPE
Just want to get the right ones for mine.
Hi,
You are girlLentaja careful he might be Bulgarian Mafia and 'boot strut' could be Bulgarian code....![]()
Looking to fit these too.. Out of stock again...
Will do this when back in stock....
Update:
I found these instead. Not as cheap but not far off. I have compared the specs to the one listed above by WhiteCupra290 and they match. Although they list the length as being 515mm.. Hope this is a typo. As the OEM P/N's and model number are the same. Also it's title says bonnet and tailgate...
So fingers crossed they do the job...
Thanks to all for the info... Great little mod.....
Update : update : Just measured the strut on mine and fully open it is exactly 515mm in length.... Feel a bit better now..![]()
Funny you say that as I did see in a pic or video that they were upside down.... Thanks for the info.Only thing you may have to do is install them the other way up, i.e cylinder at the top. Depends on which end has the cranked bit on.
Has anyone tried doing this on an ST yet?
It's a heavier lid I guess so might need more substantial struts but it was a feature I used a lot once I'd fitted it to my 280, and I miss it on the ST. I kept the struts so might have a squiz later, once the monsoon passes....
No problem, they work fine. Mine are on the second car now , missus does complain sometimes that the boot is harder to shut but I tell her it's breast developingFunny you say that as I did see in a pic or video that they were upside down.... Thanks for the info.
No problem, they work fine. Mine are on the second car now , missus does complain sometimes that the boot is harder to shut but I tell her it's breast developing![]()
