Boot Gas Struts
AdamC11
191
Bolton
Hi.
I have just fitted the above to my MK3 but the boot is not popping up when i hold the boot release on my fob.
Any advice would be gratefully appreciated.
SwinDan
71
Swindon
Does it open if you lift the boot without using the release handle when you press the boot button as you may have to program this function using obeleven or carista
sheffield
49
I did this on my 184, changed struts over, didn't have to reprogram anything, just hold the boot button on fob down a little longer than previously.
SwinDan
71
Swindon
Sounds to me like you haven't fitted strong enough boots struts if it won't even push the lid up once you have opened the latch
AdamC11
191
Bolton
Hi kazand,
Thank you for your response.
Can you send me an actual link so I can order the correct ones.
AdamC11
191
Bolton
Thanks for the response.
I have a 2014 MK3 SE 5 Door Tech Pack.
When I select the correct struts, what options should I select?
