Boot Gas Struts
Lawtonater9
28
Manchester
Has this worked for anyone, and will it open holding the open button with key( the same way all the windows come done)? Or just using the normal boot release, and the stronger struts lift the boot lid automatically?
Thank you,
Kenny
As above. No other mods required just press and hold the boot button on your key and the force of the new struts opens the boot on its own.
Anybody else feel like God doing this? just walking to your car and opening the boot without touching it. It's my party trick.
The service manager at my local dealer was that impressed he asked me where I got them from.
kendo08fr
37
38
Glasgow
:rofl: I'm buzzing thinking about my Leon doing it.
ibizasc-chris
Ibiza SC Sport Driver
Oct 7, 2008
60
Hi,
Anyone done this on an ST yet? Is it just the same struts needed or heavy duty fancy things?
Deleted member 103408
Hi,
can confirm these struts are no good for ST however check out pos 51 and 52 they give some info and advise of where to look
Sent from my SM-G920F using Tapatalk
heliophile
146
39
Manchester
These are the exact ones you want, fit great, raise the boot perfectly will fit 3 or 5 door
Another satisfied customer here. Just fitted mine, took 5 mins. Thanks for the info everyone.
paddy6789
1,627
1,082
Preston, Lancs
Is that possible? It amused me slightly when I got my car that it didn't have them.
I got my bonnet set from some guy in Russia - cost me £30 (including VAT) and they were installed in about 3 minutes.
The hardest thing I came across was removing the bonnet support stick thing (I’m sure there’s a proper term for it!). But a Stanley knife to the rubber grommet sorted that stubborn bugger out!
Seat Leon Cupra 290 DSG Black Edition (Alor Blue) Stage 2
JsyCuPrA
226
20
Oxfordshire
Fitted my boot struts last year, but have a slight issue, the boot will only open on the key fob, the manual boot catch doesn’t work? Is this a setting thing ?
Big poppa John
136
Staffordshire
Do you have any pictures and a link to the struts?
wolfie150
36
Birmingham
Hi...am I right in assuming the one quick press on the keyfob will open it as it does now and only a sustained hold will propel it skywards...only asking as I have quite a low garage and well you can guess the rest.
paddy6789
1,627
1,082
Preston, Lancs
You are correct :)
bradleymarky
75
Huddersfield
Just fitted mine and work well. I quickly realised its a lot easier fitting the bottom part of the strut first.
Is there still nothing for the ST yet ??
ryzzey
165
42
Dorset, UK
I also bought the Stabilus struts previously mentioned on ebay, took 5 minutes to fit and they work so well.
It does make it pretty hard to close the boot though, you almost need both hands! But worth it for the opening all the way when holding down the boot release button on the key fob.
As already mentioned it is easier to fit the bottom first then the top, I held the boot up with my head when fitting which wasn't a problem!
