niallain
273
53
Cardiff
Upgraded my MIB1 system last night with the instructions in post #72, had a few codes to clear after but there is still one code that I cannot clear
B201A00
Anyone else run into this issue?
darkstar815
13
Trouble codes:
B201A00 - Checking software version management
static
this is the code that you need to use the hex calculator to get rid of here are the instructions from the other forum
We enter the 5F
Adaptations
Confirmation of installation change
We copy the value that shows us (XXXX)
We use a calculator that has XOR ( Bitwise calculator for example)
In hexadecimal we put the value that we have.
We give XOR.
We put these values ​​C9D2 and give the = symbol to calculate it.
The value that you put us, we put in Confirmation of the modification of assembly and We accept.
After accepting we will see that the value has not changed with respect to what we had at the beginning. IT IS NORMAL.
If you do it with VagCom leave a space between. (XX XX) when inserting it again.
Once done, do the scan again and clear the bug definitively.
niallain
273
53
Cardiff
Trouble codes:
static
We enter the 5F
Adaptations
We give XOR.
Thanks for this.
Any ideas how to use the XOR calculator correctly?
Current value is 88F7, however there are 2 inputs on all the calculators I have found.
Trying to split it into 88 and 7F only resulted in a output of F7, which the system did not accept when I tried to apply the value.
darkstar815
13
Thanks for this.
I have used the XOR calculator if all correct the code you need to input should be 88f7 if you are inputting it using OBDELEVEN then you do not need to put in a space
niallain
273
53
Cardiff
Sorry, should've been a little clearer.
Photos below show the XOR calculator I'm using.
OBDEleven doesn't accept "7F" as a valid value
Cannot have just 1 input
darkstar815
13
The output of the XOR calculator should be entered into the fault code
so in number one put the code within the error
In number 2 put in C9D2
press xor
the output you are given needs to be entered in via vcds or obdeleven
niallain
273
53
Cardiff
press xor
Like so?
Will give this a go now.
darkstar815
13
number one should be the current value not the error code number so i can see you posted the current value of 88F7
So 88f7 should be number 1
and number 2 should be C9D2
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Just did mine today and all appears fine. Faults cleared with obdeleven but not checked for sw version mgt error. Ran out of time so just cleared codes and tested HU. All seems a little slicker when navigating round the various functions.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Not long Andy. Approx 10 mins per update. 0330 is a precursor to 0346. Once done scan and clear error codes and you will e golden. I should scan again to check for 0155 error and update xor value if present. I ran out of time when updating and only scanned and cleared codes once per update.
Andy1977
92
18
The software on my 2013 car is 0171, will I have to run other updates before I do the 0480 one?
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Not sure. Maybe yours is a mib1 HU as I only went to 0346?
Have a read of pg 41 of the clubseatleon.net thread as it gives step by step guide on update process. This is where I got info on 0330 precursor to 0346 update for mib2 HU.
