OBDeleven modifications
Miguel 7
R ST
Jan 23, 2017
350
56
29
I managed to do some coding today
FIS Carbon
One touch folding mirrors, and passenger mirror moving down when reversing
Mode light red on all modes
Alarm chirp with locking
FR logo when switching the radio on
Planning to do carbon on infotainment screen
Windows closing when detecting rain
Wipers on service mode when opening bonnet
Thanks all for the posts in this thread, helped me a lot :D
Anything else worth doing?
Smithcd
49
FIS Carbon
Things I think are worth doing that aren't listed or standard in my car are...
-increasing the brightness of drl's/ reverse light/ rear fog light
-needle sweep
-alter the accuracy of the mpg
-dial lights permanently on
-Scandinavian drl's (rear leds on as well)
-cornering lights
Miguel 7
R ST
Jan 23, 2017
350
56
29
-needle sweep
-cornering lights
Already have the needle sweep, dial lights and scandinavian lights
Dont want to do cornering lights until I change them to leds, also planning to replace the reverse light to led first but thanks for your reply
Harrymorgan1
Seat2016
Mar 5, 2017
24
Think this is the one ...
Ambient door light with flashing and color change
With this mod, bringing the doors in red, when flashing, the door on the side of the indicator flashes between red and white.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Select - Leuchte16BLK SLB35BLK SL KC9
4 - Submenu - Lichtfunktion C
5 - Change value to Blinken links (beide Phasen) BOTH SIDES OF INTERMITTENT or Blinken links (Hellphase) ONLY WITH INTERMITTENT LEFT
6 - Select - Leuchte16BLK SLB35BLK SL KC9
7 - Submenu - Dimmwert CD
8 - Change value to 0
9 - Select - Leuchte16BLK SLB35BLK SL KC9
10 - Submenu - Dimming direction CD
11 - Change value to Minimize
12 - Select - Leuchte16BLK SLB35BLK SL KC9
13 - Submenu - Lichtfunktion E
14 - Change value to Blinken rechts (beide Phasen) BOTH SIDES OF FLASHLIGHTS or Blinken rechts (Hellphase) ONLY WITH RIGHT INTERMITTENT
15 - Select - Leuchte16BLK SLB35BLK SL KC9
16 - Submenu - Dimmwert EF
17 - Change value to 0
18 - Select - Leuchte16BLK SLB35BLK SL KC9
19 - Submenu - Dimming direction EF
20 - Change value to Minimize
21 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
22 - Submenu - Lichtfunktion A
23 - Change value to Blinken links Hellphase
24 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
25 - Submenu - Lichtfunktion B
26 - Change value to Blinken rechts Hellphase
Sent from my SM-T520 using Tapatalk
Hi, I tried this and it partly worked. But both sides always blink when either inductor is used. I tried playing round with the blinken lichts and rechts and hellphase etc and still no joy.
Can anyone help??
Also whenever I now use a mode with white door lights, they don't work - only the red. Is this normal? Thanks
mjather93
17
Has anyone had issues changing the infotainment screen to carbon. Tried today and set the skin to value 3 and when resetting my unit it froze on the FR boot screen. It then wouldn't revert back until after a few attempts. How has other people got it working for carbon infotainment? 64 plate fr if that makes any difference.
marinipersonal
78
after few hours of pleasant reading, couldn't/wasn't able to see how to activate the auto light switch. Just replaced the senor (behind rear view mirror), wipers working fine now, the switch was installed, but getting error when selecting Auto. Question for the good souls here is: what should I change on OBD11 to activate the sensor/stop the error?
KoNG
509
107
London
Enabling the sensor, in vcds
Select 09 - Centr. Elect.
Select 16 - Security Access (Note; couldn't remember if this was needed or not, don't think it matter if you put it in and its not needed)
input 31147
Select 07 - Coding
Select Long Coding Helper
Byte 6: bit 0-1 light sensor Installed
Byte 7: bit 5 ticked
Byte 7: bit 7 ticked
rest of activation you can find here http://www.seatcupra.net/forums/showpost.php?p=4630006&postcount=38
marinipersonal
78
input 31147
Select 07 - Coding
Can't find the options on obd11, sorry.
marinipersonal
78
input 31147
Select 07 - Coding
Just a quick update, all working. Appreciate your help.
Using OBDEleven Pro, when selecting long coding, the next stage was a list, not the codes as expected. To switch modes to be able to edit byte and bit, there's a sign on the right top corner. Thanks again.
marinipersonal
78
I think I bricked my old copy VCDS lite cable!
Is OBDEleven the cheapest and easiest replacement?
Never used VCDS, but the Pro version of the OBDEleven is great.
So far didn't had much time, but activated the light sensor, cornering kights, increased intensity of the reverse light, closing mirror when locking the car with just one click, and loweering mirror when reverse is selected.
Will go for many more.
The app keeps a history for the changes. Very helpful if something goes wrong.
leonisis
Quick enough for me....
Mar 21, 2016
256
66
Bangor NI
Install the app on your phone or device and buy it through there. Some deals on with credits at times.
Sent from my Pixel XL using Tapatalk
Blokie
20
Picked up my 2016 FR 184 today, and luckily my odbeleven turned up just before I left to collect the car!!
Been having a play and here's the progress:
Worked fine:
Needle sweep
OPS / Park Pilot
Auto-folding mirrors
Rear LEDs on permanently
Tear drop wipe
Disable yellow warning light
Infotainment carbon background
Failed:
Make all door lights red.
For the door lights I tried 2 methods, both wouldn't work, as follows:
This one didn't have A16 within Leuchte17TFL (step 4) to change:
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte17TFL R R SR BLK BLK SRB3TFL light KC3
4 - Sub - Lichtfunktion A16
6 - Change value to 127
7 - Select - Leuchte16BLK light SLB35BLK SL KC9 Select B16
8 - Sub - Lichtfunktion B16
9 - Change value to 0
..and this one didn't have environmental Luz 3 (Step 8) to change:
2 - Adaptation
3 - Select - Leuchte17TFL SRB3TFL R R BLK BLK SR KC3
4 - Sub - Lichtfunktion A 17
5 - Change value to Off
7 - Sub - Lichtfunktion B 16
8 - Change value to environmental Luz 3
Any ideas on the failed one??
ClrDaLane
Door lighting always red
1. Module 09, 31347
2. Adaptation
3. Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
4. Lichtfunktion A17 = Nicht Aktiv
5. Leuchte16BLK SLB35BLK SL KC9
6. Lichtfunktion B16 = Ambientelicht 3
This worked for every 2013-2016 Leon I've tried it on.
ClrDaLane
Worked fine:
Needle sweep
OPS / Park Pilot
Tear drop wipe
Failed:
2 - Adaptation
2 - Adaptation
1. Module 09, 31347
2. Adaptation
