OBDeleven modifications
Blokie
20
Door lighting always red
1. Module 09, 31347
2. Adaptation
3. Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
4. Lichtfunktion A17 = Nicht Aktiv
5. Leuchte16BLK SLB35BLK SL KC9
6. Lichtfunktion B16 = Ambientelicht 3
This worked for every 2013-2016 Leon I've tried it on.
Thanks. I've enabled as above but it's too sunny to see if it's worked yet!!!
Blokie
20
Within 24 hours of picking up my MY16 FR 184 I've done the following:
Needle sweep
Park Pilot (OPS)
Auto folding mirrors
Rear LED's permanently on
Tear drop wipe
Make all door lights red
Disable the yellow warning light
Disable beep when you open a door with ignition on
Infotainment carbon background
Digital odometer in FIS
Refuel quantity display
Increase Intensity of Rear Lights
Increasing the brightness of rear fog light
Increasing the brightness of reverse light
Remove oil temperature from FIS (was on)
To do once I have enough data:
MPG Accuracy change
...and I also updated the sat nav to the 0820 version from 0635.
Harrymorgan1
Seat2016
Mar 5, 2017
24
Hi, I tried this and it partly worked. But both sides always blink when either inductor is used. I tried playing round with the blinken lichts and rechts and hellphase etc and still no joy.
Can anyone help??
Also whenever I now use a mode with white door lights, they don't work - only the red. Is this normal? Thanks
Can anyone help with this? Thanks
Smithcd
49
I seem to have tarted round with my setting and lost comfort open of my windows using the fob and also lost one touch closing on my front passenger window but gained it on the drivers side (drivers side bugged me not having it but I put it down to a dodgy switch) to my knowledge I haven't altered anything to do with the windows
Miguel 7
R ST
Jan 23, 2017
349
56
29
You should be able to switch these back on through the menu in the car > settings >windows/mirrors and check whats ticked
Blokie
20
Can someone please share the coding/adaptation for the front and rear tear drop wipe? Thanks in anticipation.
No idea on the rear, but the front is as follows:
Electronic control module 09-. Code (31347)
10 - Adaption
(17)-Windshield wiper-Traenenwischen Front Status - set to active
Blokie
20
Does anybody know how I can remove the coolant temperature from the FIS?
I found options for refuel quantity, speed and oil temperature, but not for coolant (which is on).
marinipersonal
78
As you're saying, I also couldn't find how, as I'm aware they're under reading badly.
Any OBD adaptor, using either torque or OBD11 would say it's over 100 when full on, but the FIS reading never, ever showed over 90. Same for Engine oil. So I'll remove them from the quick access from the FIS.
Miguel 7
R ST
Jan 23, 2017
349
56
29
Coolant temp never went above 90 on mine too but oil does all the time, worth having it to see when it's safe to start pushing :)
marinipersonal
78
Mine, the coolant is always 90. Other readings shows 102, 103 during the exact same time. For oil, during winter was always 90, under normal driving I must say, rarely going over 93 or 94. Now during summer, easily at 103, and up to 106 when pushing a bit (acording to the FIS reading). Not alarming, but if it's over read as the coolant reading, would be at over 110? Will keep checking before removing the option.
