Cable tied the rear brake shield back on until the replacement arrives
Anyone know do you need to remove the entire caliper on a Cupra to remove the brake disc?
When I've changed discs before on cars normally you can just remove one bolt and loosen the lower bolt and rotate the caliper out of the way. Not done discs on the R yet but my EP3 Type-R I had you could do it.
