OBDeleven modifications
p.eco
227
17
Ireland
There's an option in the settings to display clock in standby mode. Check that it's still ticked.
You are right, it was off there i didn't even know that can be turned on and off in infotainment. It must went off when i reset the system some time ago. Thanks! I thought i messed up something when i played with obdeleven.
Sent from my Nexus 6P using Tapatalk
dw911
1,036
7
Does anyone know if it's possible to activate the different analogue clock choices when the infotainment is in standby? Mine only has a digital clock, but I know someone with an ST that has different choices when you put your hand near the screen.
+1
I'd be interested in how people got the analogue clock too
Glarh
244
21
Before I have a go with my device do I need to have the engine running ? Sorry for the lame question. Just want to do it right. Thanks
Glarh
244
21
So just had a play and the soundaktor kept saying failed my going home feature has appeared to have gone when I lock unlock the car. Scandinavian rear lights worked. Needle sweep worked. I couldn't find the mirror fold option. If someone could help or shed some light that would be great. Thanks
Glarh
244
21
Also alarm chip was activated but didn't work
jeff4066
33
Restore LED lights to original
Hi, can anyone give me the the settings for restoring the drls to original setting.
p.eco
227
17
Ireland
You can do that the same way as you turned them on or go to apps an switch them off. This cost 10 credits though...
jeff4066
33
I have the pro version so don't need the credits, I just want to know how to restore to original as I tried to code something and it didn't work but don't know how so rather than play around making more mistakes I'd like some help to do it.
p.eco
227
17
Ireland
And what did you do with them? First we need to know what function exactly you want to revert? Scandinavian lights? Brightness?
leonisis
Quick enough for me....
Mar 21, 2016
256
66
Bangor NI
Hi does anyone know if it is possible to code the mirrors to unfold when unlocking the car ? The Golf works that way and I quite fancy mine the same way. Any suggestions?
jeff4066
33
I managed to revert them back to original wasn't to difficult, but thanks anyway.
One thing I can't get to work but I would like to is the 5 flash indicators to replace the 3.
It only gives me a value of 0-3 and accepts me putting in a 5 but it doesn't work
jeff4066
33
If they fold in on locking they should unfold unlocking
Brucey CUPRA
37
Co. Durham
You need to go into car menu > setup > factory settings > lights and reset it to get them to work. I had to do this to get the 5 flash working.
jacko5
187
35
60
UK
Ok chaps i have a Obdeleven from when i had my Sirocco.
When i try to do some coding i put in 31347 in the security access code in it says invalid code ( also does this with a Vagcom lead ).
My car is a Seat Leon 2009 FR Diesel with 170bhp CR Engine.
Has the security access code changed on this car ?
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
I had to reset the infotainment system post coding to enable the indicator flash change.
