Hi Guys, my first post here
1 - I got a question, is it posible to turn of the DRLs when I set the Light switch in position OFF??
2 - If it is posible, will the DRL still turn on, when the light switch is set to AUTO??
I have sweeped the net and this thread and no luck.
Thanks for all the contribution you guys
Max
2016 - Seat Leon ST FR 1.4 - 150HK/180HK
Found the code and added some text
Seat Leon 5F VCDC LED Daytime Running Shutdown
Most cars in Europe have the DRL ON regardless what position your light switch is set on, here is a fix.
This code will turn OFF the DRL in light switch position "0"
1- select STG 09 (vehicle power)
2- STG Access Permission -> Function 16
3- Enter access code 31347
4- STG adjustment -> function 10
5- Channel (9) - Select daytime running lights only in switch position Auto
6- put emphasis on active
This code ads an extra line in Light setup menu on the radio DRL ON/OFF
1- STG 09 cent.elec.
2- STG Security Access Function 16
3- Security code 31347
4- 10 adaption air entered.
5- (2) select Daytime running lights that are activated by BAP Operating sequence possible
Have fun i do
Max
