Phillips1795
VCDS - How To Guides - MK3 Leon 5F
Havsgaard
186
Denmark
I have the obd eleven app and tried as per previous post.
The mirror fold keeps saying 'something went wrong' please retry.
The lock unlock chirp is advising enabled.. Wierd
There's been problem with the app - I also had that error last week, but with the latest update it is
fixed.
This might be a stupid question, but it is the PRO version of the app you have - the paid one?
Havsgaard
186
Denmark
Anyyone tried something similar like this - it sounds interesting- and if it works on seat?
Increased sensitivity of the throttle pedal
Controller 01- Engine
07 - Coding
Byte 0, Bit 0-2,
Change from (01) to AUDI (02) this will dramatically reduce lag on pressing accelerator pedal.
Havsgaard
186
Denmark
Ok i just had a short drive with the throttle setting set to audi, and it actually feels more dynamic in dynamic mode! and the distance i have to press speeder before response isba bit shorter. Its not drastically changed but it felt somewhat better. Will have to do some longer drives
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Does not sensitivity changes during drive profiles?eco and sport modes are quite diffetent when putting pedal to the metal
VAG Familia
2016 LEON FR 110kW
Winder123
142
North West
Is there a security access code that's needed to change this?
Sent from my E6653 using Tapatalk
Havsgaard
186
Denmark
VAG Familia
2016 LEON FR 110kW
Yes, it does. But in sport it also goes way too high in revs for my liking in daily driving. My initial impression with the mod, is that the speeder response is now closer to sport mode, while in dynamic. But I will need some more driving before I can get a good feel
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
I will try this weekend.and report :-D it will be great having better response in sport mode
VAG Familia
2016 LEON FR 110kW
Havsgaard
186
Denmark
VAG Familia
2016 LEON FR 110kW
Looking forward to your report - changing things like this, is like washing the car. You imagine it to be better and the differences, or lack of, is something you suddenly become aware of because you start focusing it :)
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
It would be usefull mod if it works.once a while i take my gf and we go up in the hils.love corners and there will be real test.
VAG Familia
2016 LEON FR 110kW
Havsgaard
186
Denmark
Can someone with a Leon TDI FR DSG - readout byte 0 from - and perhaps tell me what it states.
07 - Coding
Byte 0
My byte 0, was standard saying 11, with changes it says 12- the number 2 is alright, but I am wondering why it stated '1'2 - what vehicle type is that?
Deleted member 98136
Can anyone shed some information as to the differences between the standard Obd 11 and the OBD 11 Professional versions please ?
I note on ebay that the standard is approx £32 and the Pro is approx £52, but when I read thro' the description for each version they seem to list the same capabilities. Or am I missing something ?
Havsgaard
186
Denmark
Pro version allows for coding and adaption, standard is more or less just for read out and live data, not of much use.
Appreciate that Havsgaard, now I know what one to go for, Thank you.
Havsgaard
186
Denmark
07 - Coding
Byte 0
It is perhpaps newer than VCDS 12.12. I just tried with my old 12.12 VCDS cable, and the value 11 doesn't seem to exist in byte 0. It only had 00 and 08 stated as possible values in bit 3-5.
So if someone could be so kind to read out Byte 0, bit 3-5 possible values in newest VCDS version then I will be grateful. Its just that I need an explanation to why byte 00 got value 11/12 instead of 01/02 :confused:
mick_n3
192
8
Kettering Northants
Has anybody managed to code rear lights with drls on a 2016 MY,
Got my new 15.7 cable today and can't get it to work tried both the short way and the longer one on the stemei.de website but neither are working, cable is working ok as I've managed to do mirror fold etc
Thanks in Advance
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
I done my 2016 fr with 15.7.1 vcds.ist quite easy,but i have to disable all other inside illumination.
Coding was taken from this SCN forum,dont remember page
Edit: screenshot i found:
VAG Familia
