What did you and your MK2 do today?
richicupra
1,823
9
30 seconds from home, clutch hits the floor... the bleed block assembly has popped out of the casing. Hoping it's an easy fix.
Update: one of the metal retaining clips has snapped so it's not holding the pressure in the line. Hopefully new part arrives tomorrow.
Updown789
141
Painted centre dash pieces and cluster surround matte black. Also had two new toyo t1-r's put on the front and a 4 wheel hunter laser alignment
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
Kicked it's head in yesterday morning over the Black Mountain Pass in South Wales - Epic driving road. Unfortunately the video footage isn't suitable for public forums, but the few screenshots from the action cam show just how awesome the road and view is
richicupra
1,823
9
What a view!
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Cracking road :D
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
It is indeed, it's an hour away but you get it all to yourself if you go early enough (If you can make out the upside down time) stamp:whistle:
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Looks good. Personal preference - but I put a few small selt tappers in the corner of where the back centre piece starts so it follows the bumper line a little better. Might be worth considering;)
unerdanielson
205
Thanks, I put a few in just for piece of mind. Tried to follow the line under the bumper as best I could. Think it looks okay. Next on my list is to make a honeycomb centre grill.
kazand
Jun 6, 2010
4,138
73
Brum
Done it a few times, usually start down on the A465 then head north-ish, usually end up in Dumas Mawddy or Bala, then turn for home :D
Jaruba
39
Finland
This happened in friday but anyway!
MAHA dyno gave great numbers. Worst run was 373 BHP and 453 Nm. Best out of 3 runs was 388,2 BHP and 461,5 Nm. Colder weather gives easily +400 BHP
I don't have words anymore, 4000 rpm to 7200 rpm is now so smooth and rev limiter with 3" non-resonated catback gives nice bangs.....
Check "Spoolin´ Shirley" channel in youtube
richicupra
1,823
9
373 bhp from a stage 1+ map?
