IMO 1000 miles is way too early to start flooring it, I'm staying below ~4000-4500 RPMs/~70-80% of max throttle till it hits a 3000-mile marker.I have just swapped my 13 plate Cupra for the new one and it feels quicker and the ride is better, loving the manual gearbox aswell. Old Cupra did 6.7 to 60 not timed this one yet waiting till I hit 1000 miles before I give it full beans.
I see the sub in the spare wheel well - is that a spare wheel there as well? If so it looks like you have to remove the sub to get the wheel out - 4 bolts. Am I seeing it right?
Car now has 1100 miles on the clock and the engine hasn't been driven in properly yet, I can feel it, difficult to explain but it has small 'gaps' in its running now and then during acceleration.
Tõnu
Tõnu
How do you know that labouring is worse to a new engine than flooring it?.. The biggest threat to a new engine is labouring it - trying to accelerate in too high a gear and making the engine labour. ..
Labouring isn't good for any engine really, new or old.
BTW I didn't say anything about labouring before.
Tõnu
I had a go with the ecotrainer yesterday - it's interesting to see just how you need to drive to achieve a high score. I managed 84 points.
I was brought up to believe that labouring is a BAD thing and in the past it was pretty obvious when this occurred and anyone with a reasonable amount of mechanical sympathy would respond accordingly.
These days of dual mass flywheels, fancy fluid engine mounts and the like, the driver is well isolated from the vibrations of a labouring engine. Despite this change gear lights on the dash seem to encourage letting the engine labour to the point where it is still fairly obvious.
However economical I want to be I can't bring myself to run the engine as low as the lights would suggest.
This is me driving on the motorway 120 km and 20km through the city had a few races as well lol....![]()
The annoying thing is, the DSG drives the car 'laboured' most of the time in 'D' mode. All to do with eco stuff i guess. Left in sport mode the revs stay higher as it holds the gears for longer. So to combat the labouring I get in 'D' mode, I've been using Sport mode and bit and also been making use of the flappy paddles in manual mode to take the revs up that bit higher.
