Phillips1795
VCDS - How To Guides - MK3 Leon 5F
riskfactorr
19
I understood that this is true for 2013/2014 models, on 2015 it unfolds mirrors when you unlock the car, so my question is if it's possible change the behavior via VCDS coding, probably not...
There you go, mine is 13 that is why I was shocked to hear that they unfold when unlocked.
My previous company Audi A3 (MY15) and my Citroen DS3 unfolded mirrors when unlocked and folded when locked which is not so bad because when I move away from the car and think whether I locked it or not my mirrors always let me know ;)
hm227
19
Is it possible to programme the door mirror indicators to sweep like on the new Audis or is new hardware required? I'm sure I've seen a clip of a Leon mk3 having this.
dw911
1,036
7
Nope it's not possible with the existing leon mirrors
john doe
55
I have over 250 mods via VCDS (Ver 15.7.X). If you need something special, pls ask (type: Lights, BAP, FIS, etc.).
Acctually I don't know yet. Done some modds as staging/carbon fibre/cornerlights/folding mirrors/laptimer, but since we all don't really know whats possible to do with the Leon.
Is it possible that you could sent it to me via mail?
Or you rather keep it to yourself?
If you have any pointers on whats good to have, you can write it down here.
vime81
22
Milan
I have tried to enable all menù related to the mirrors (spiegel) but the fold/unfold is the same.
kopnyr
64
Nitra, Slovakia
Hello, in attachment you can find some "new" VCDS mods. Everything tested with VCDS 15.7.X cable.
SEAT LEON 5F - Road Sign Recognition (Ver01)
STG 5F, Adaptation,
Fahrzeug Funktionsliste BAP-traffic_sign_recognition_0x21, „activated“
Fahrzeug Menü Bedienung-menu_display_road_sign_identif¬ication, "activated“
Fahrzeug Menü Bedienung-menu_display_road_sign_identif¬ication_over_threshold_high, „activated“
STG A5, 20103, Coding, Byte 1 Bit 0 true - "01 Verkehrszeichenerkennung (VZE) aktiv"
STG 17, Coding, Byte 5 Bit 2 true - "Verkehrszeichenerkennung verbaut/aktiv"
STG A5, Adaption, Zeichen Ende der Geschwindigkeitsbegrenzung anzeigen, „active“
Gültige Zusatzzeichen anzeigen, compare with value "00100111"
Attention: After 2-3 minutes an optical/accustical information will be shown on screen, that road sign regognition is restricted working.
SEAT LEON 5F - Road Sign Recognition (Ver02)
STG 5F, Adaptation,
Fahrzeug Menü Bedienung-menu_display_road_sign_identif¬¬ication, "deactivted“
Fahrzeug Menü Bedienung-menu_display_road_sign_identif¬¬ication_over_threshold_high, „activated“
SEAT LEON 5F - Closing Windows in Case of Rain
STG 09, 31347, Adaption
Access control / Zugriffskontrolle 2-Regenschliessen_ein_aus, "active"
Access control / Zugriffskontrolle 2-Regenschliessen, "permanent"
Access control / Zugriffskontrolle 2-Menuesteuerung Regenschliessen, "active"
Coding, STG - RLS, Byte 0 check Bit 1 and 2
SEAT LEON 5F - US-Headlights (US-Tagfahrlicht) on Mode "Sport"
STG 09, 31347, Adaptation,
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,127
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 4
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,Blinken rechts Hellphase
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,127
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,minimize
Update (2015-02.06): Following is a tutorial how to deactivate US head lights both sided during any turn signal is active.
STG 09, 31347, Adaption,
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,minimize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,126
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
(4)-Leuchte1BLK VRB20-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte1BLK VRB20-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte1BLK VRB20-Dimmwert AB 0,127
(8)-Leuchte1BLK VRB20-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte1BLK VRB20-Lichtfunktion D 0,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 0,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 0,minimize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte1BLK VRB20-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte1BLK VRB20-Dimmwert EF 0,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 0,minimize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte1BLK VRB20-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte1BLK VRB20-Dimmwert GH 0,126
(19)-Leuchte1BLK VRB20-Dimming Direction GH 0,maximize
SEAT LEON 5F - Change Radio Logo for Intro
STG 5F, Byte 18, change hex-value for your next new logo.
01 – FR
02 – Cupra
03 – Ecomotive
SEAT LEON 5F - Drive Profiles in FIS
STG 19, Coding, Byte 8 check Bit 4
SEAT LEON 5F - ESP Off (3 Modes) FR, CUPRA
STG 03, Coding, Byte 29, change the last to hex-values to 06, switch on the ignition again.
SEAT LEON 5F - Ambient Light Modifications
Ambient light – brighter
STG 09, 31347, Adaption, (2) Ambientebeleuchtung-Defaultwert Ambienteprofil Tuerr, Value: „127“
Ambient light shines allways in red
(4) Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A17, „nicht aktiv“
(5) Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B16, „Ambientelicht 3
White, blinking ambient light during turn signal is activated
Information:
Leuchte 16 = red ambient light
Leuchte 17 = white ambient light
Leuchte16BLK SLB35BLK Lichtfunktion C, „Blinken links (beide Phasen)“ / Alternative „Blinken links (Hellphase)“
Leuchte16BLK SLB35BLK Dimmwert CD, „0“
Leuchte16BLK SLB35BLK Dimming Direction CD, „min“
Leuchte16BLK SLB35BLK Lichtfunktion E, „Blinken rechts (beide Phasen)“ / Alternative „Blinken rechts (Hellphase)“
Leuchte16BLK SLB35BLK Dimmwert EF, „0“
Leuchte16BLK SLB35BLK Dimming Direction EF, „min“
Leuchte17TFL R BLK SRB3TFL Lichtfunktion A, „Blinken links Hellphase“
Leuchte17TFL R BLK SRB3TFL Lichtfunktion B, „Blinken rechts Hellphase“
White ambient light during reverse light is activated
Leuchte16BLK SLB35BLK Lichtfunktion G, „Rückwärtslicht“
Leuchte16BLK SLB35BLK Dimmwert GH, „0“
Leuchte16BLK SLB35BLK Dimming Direction GH, „min“
Leuchte17TFL R BLK SRB3TFL Lichtfunktion C, „Rückwärtslicht“
Leuchte17TFL R BLK SRB3TFL Dimmwert CD, „127“
Leuchte17TFL R BLK SRB3TFL Dimming Direction CD, „max“
SEAT LEON 5F - SLOW Dimming Daytime Running Lights
Leuchte2SL VLB10-Lichtfunktion E 2 - Blinken Links aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte2SL VLB10-Lichtfunktion F 2 - Blinken Links aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte2SL VLB10-Dimmwert EF 2 und "Neuer Wert" auf 35 ändern
Leuchte2SL VLB10-Dimmrichtung EF 2 und "Neuer Wert" auf Verkleinern ändern.
Leuchte3SL VLB21-Lichtfunktion E 3 - Blinken Rechts aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte3SL VLB21-Lichtfunktion F 3 - Blinken Rechts aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte3SL VLB21-Dimmwert EF 3 - 35
Leuchte3SL VRB21-Dimmrichtung EF 3 – Verkleinern
CARBON BACKGROUND TO MEDIA SCREEN
Select 5F ( Information Electronics )
Then coding - 07
Then click on "long coding helper"
Go down to byte 17
Un-tick bit 1
Tick bit 2
Exit
Click "do it"
After it says code accepted - come out of all the controllers
Do a system reset - hold power button in for 30 seconds
Reactions: Zain Iqbal
Chrismalkinuk
102
Stoke on Trent
It's worked before then the car went to seat and had the infotainment system replaced and now it won't redo it. I'll check the version in a minhte
kopnyr
64
Nitra, Slovakia
uupss, if do you have the newest infotainment unit, you could make VCDS mods only thru 15.7.3 cable :funk:
kopnyr
64
Nitra, Slovakia
Off Road Display - Instructions:
WARNING: VCDS users that have a HEX+CAN, or Micro CAN Cable please note that this tweak (and any tweaks) on MIB2 units (address Hex5F) should only be implemented with Ross Tech software version 15.7.3 (or later).
REQUIREMENT: This tweak will only work on MIB2 units that have SATNAV installed (don't bother trying if a SATNAV is not present).
Step 1. On Select Control Module screen click "Select"
Step 2. Select 5F-information Elect
Step 3. Go to step 4 - Note: I've had reports from some forum colleagues that a security code was needed. If the adaptation channel settings in Step 5 are locked:
Step 3A. Go back to the Open Controller screen and select Security Access-16
Step 3B. Enter the magic number 31347 (if this doesn't work- exit RT software, wait a while with the ignition-on and try 20103)
Step 4. Select Adaptation-10
Step 5. Change the following adaptation channels:
(81)-Car_Function_Adaptations_Gen2-menu_display_compass - set to active (default not active)
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high - set to active (default not active)
(41)-Car_Function_List_BAP_Gen2-compass_0x15 - set to active (default not active)
Exit the Ross Tech software
Step 6. Reset the MIB unit - press and hold the ON/OFF button on the infotainment unit for greater than 10 seconds.
PICS
Deleted member 98136
Thanks for posting kopnr -
Would presume that 328ft in middle of screen relates to your actual height above sea level ?
