Well, I've managed to set blinking on rear taillights.
1) Set tailights as DRLs (as in tutorial, Leuchte 23, 24, 26 and 27)
2) Set blinking as for front DRLs (as in tutorial for the front ones, except it's for Leuchte 23,24,26,27, G, GH)
3) Deactivate yellow bulbs for blinking (Leuchte18 and 19, function A - not active).
See my result: youtu.be/1wiPEyqLTr0
The only
problem is that whenever I take the key out of the ignition (so tailights are not running any more as DRLs), in the back of the car the is no lightning for emergency blinkers.
Can you suggest me a solution to try?
For the moment, I am thinking of two ways:
a) change their function from DRLs only to blinkers (as in tutorial, but instead of DRL will set them as blinkers somehow)
b) check how actual yellow blinkers were set up, and add the same function to 23/24/26/27
Any advice would be great.
Well, a solution crossed my mind, so I went back at the car and tried it out.
I went back to step 1 (setting tailights as DRLs), and I've set them to blink. They do not work as DRLs anymore, but they do work as turning lights (no matter what conditions).
youtube.com/watch?v=L286_h5MA34
Update 2:
So I thought it isn't ok to dim completely the tail lights when blinking, so I thought at the following solution:
1) during daytime (only with DRL active/or not), turning blinkers are the back DRL+Brake LEDs
2) during night (with low beam on), turning blinkers are only with brake LEDs (back DRLs do not shut off anymore when blinking).
youtu.be/HHK7Z1B4XMA
