Still got the audi! But I'm working full time now so I can afford to have something more fun, and thirsty...The Audi didn't last long then ha. Missed the golf too much?
I need to update that as I'm just in teesside now!Jarre - which way do you between Stockton and Liverpool? Haha I need vcds skills
Got it back from the garage after it being in there for 12 days with a loose input shaft to the gearbox. Next its fit the two new Goodyear Eagle F1 Assy2 tires I have waiting at my local tire place.
Not too long and its new rear brake pads. It never ends![]()
I need new discs and pads on the rear also worried about the dual mass. Dread to think about repair costs to get it done.
How'd you sort the tailgate handle? Normally just blast mine with WD40, does the job.
Remove the handle and take it apart completely. Clean all the parts, lubricate the metal pin and reassemble.
Well timing belt and water pump sorted, however they noticed a boost leak...
Never ending is it
What do you guys think to mud flaps on the mk2?
Thinking of getting some for winter as my wheels spray a lot of crap up the car.
Ah ok, sounds a bit more of a long term solution than mine haha.
You've got a 1.9tdi right? Check the intercooler pipes, the clips on there went on mine causing a boost leak.
