That looks incredible and like an amazing amount of fab time and trial fitting!
I love watching your work, wish I had the time/patience/money to do something like this.
Thanks Mate, appreciate the kind words.... and thanks for the links gonna have to watch that
Wow truly amazing
Cheers pal
Looking good. Do you got enough space for a downpipe?
Thanks, yeh got plenty of room now i've pulled cylinder 1 runner in
Incredible
Thanks for the update. Coming along nicely Graham! It's the attention to detail which I most admire from all this work, you're not content until you get perfection each step of the way which is why this is going to be such an awesome project car to look back on for many years.
Thanks as always for the kind words Tom
my perfection (OCD) comes at a price though, it takes me ages to do anything
Manifold Update
Luckily this week i haven't been away with work so i've had a few late nights in the garage progressing the manifold.
First job was standing and staring at it for an hour.... planning the sequence for welding it up, on a job like this you really need to think about it before teararsing in and welding joints which block access to others.
Once i had a "grand plan" in my head i set about final cutting and replacing some of the pipes and fitting of the pipes correctly together, then chamfered the joints to be welded.
Then i started stripping the manifold down into sections to be welded.
Before starting to weld i decided to do a few practice welds to obtain correct settings for current etc..... and to try a back-purge a weld. I found 75 amps seemed about right on the 1.6mm Tungsten.... i did buy some 2.4mm Tungstens as a welding friend suggested they would be better for penetration.
Anyhow i found the 1.6mm worked fine with adequate penetration so stuck with it.
Trial weld -
Once i was happy i started welding up the hard to reach bits - first up the bends for the turbo flange -
For those that don't know about gas "Back-Purging" basically you fill the inside of the pipe your welding with inert gas (pure Argon for Stainless Steel) - this stops any reactions with the oxygen i.e oxidation and stops any "sugaring" or rough burnt metal on the inside of the joint.
This not only helps with the flow but also creates a stronger joint, also if you don't back-purge the small parts of oxidation can become loose during the many heat cycles and detach then wreak havoc with your turbine wheel.
Shot of the inside to show the benefits of back-purging -
Next up i decided to split the collectors and weld the end pieces to them as once the collector is fully assembled access would be difficult. Welded the ends on then finally welded the collector back together -
Due to the angles involved when making the shallow angle merge collector it was really difficult to weld the rear of the collector (Where the two pipes join) but i managed to get it by sticking the Tungsten out by like half an inch.
Also due to the depth of the cut of the collector angles its impossible to have full penetration (yeh i know i said full penetration
I decided to weld the inside of the collectors, i turned the current down and carefully welded the inside edges together... to be honest i don't think it was necessary but i'm quite happy i did it (even if it was very difficult)
Inside shot of the collector after welding -
After a dose of grinding with the dremmel -
Before going any further i then re-tacked the manifold back together to check for fitment of everything (it's normal during welding for joints to pull and distort) and its easier to waste time re-checking everything than cutting and re-welding joints....
Once re-tacked i then finalised the end positions for the other collector, and prepped it ready for welding -
Ends welded onto the collector for 1-4 -
I then removed the end pipe and welded up the collector, again inside and out...then AGAIN re-tacked the bend to the collector to check the correct position -
Then i re-tacked everything back together AGAIN and finalised the bend positions to the Turbo flange and tacked the bends to the flange -
Next i decided to weld the two bends together, i did this so i could weld the inside of the pipes to each other.... i ran some welds on both sides of the pipes to keep them aligned to each other, quite hard to see but -
I then removed the bends from the turbo flange and welded round them, again access was tricky, i had to lengthen the tip and turn the gas flow up high but i got it all welded
And the most important bit - the area between the two pipes which forms the divided part of the flange -
I then filed the assembly flat with a file, so there was no nasty gaps with the turbo flange, then rebuilt the manifold again to double check alignment of everything and tacked the bend assembly to the turbo flange. Once happy i then started to weld the bends to the flange.
All done -
I've still got to grind the inside of the turbo flange to smooth the area between the pipe and flange, then weld round the inside of the flange ports.
Quite happy with the progress, thats all the very awkward welds done, "should" be plain sailing from now.
Gonna do a few hours on it tonight, hoping to be finished by the end of the weekend.
So long !!!
