The only leaky Leon guide you will need
Kruga
42
Cheshire
**** sake jinxed myself now both my footwells are drenched :/ and the backs are starting to get soaked looks like i know what ill be doing this weekend!
Dave_c85
395
Thanks for the answer, but I was being sarcastic, my bad :-S . The exhaust on these pump out loads of steam in the winter, so I'm sure some will think it's smoke. I feel bad now lol
Elliottbrophy
114
Essex
This thread is quality!! Taking the piss but letting newbies like myself know what to look out for in winter lol. Changed the thermostat and temp sensor so far and got misty as fu** windows and my second gear is a bit rough. Seen all of these symptoms just in this thread lol
rossi46
495
Kent
I'm pretty sure he isn't even sealing behind the metal door plate like he should be lol
Stage 2 mk1 LCR amd tuned 294bhp
Lowry020505
My cupra's a LEMON
Mar 22, 2014
227
Warrington,Cheshire
This exactly
This is my first winter with it, got it in febuary this year but didn't get it on the road till June, after I repaired it's countless faults,, but well worth doing,, I love it,,
Since February Iv replaced in order
Flywheel, clutch and bearing
Then the oil light came on, engine fooked, replaced that, serviced it, done oil pick up pipe
Timing belt,water pump, thermostat, alternator belt,
Then the turbo went, done that,
Ball joints,coil spring, track rod ends, for mot
Then started getting a grinding noise, replaced both wheel bearing, still there, so replaced both drive shafts,,
And last but least temp sender, no doubt something else by the end of the month,
Touch wood, it's running great at the min, I know Iv just jinxed myself posting this,:cry:
