The only leaky Leon guide you will need
aBoijj
104
Midlands
I'm almost ashamed to admit that I patched it with a glob of butyl seal that was left over from fitting a rear light assembly to another car. Did the trick tho.
Jcrosskey
28
Wiltshire
My passenger footwell is soaked. But it's dripping from the bottom back of the dashboard. Anyone know what could be causing it?
dazescort
44
isle of man
take scuttle panel off. pollen filter leaks and the sealer dries out and splits from inner wings to a posts and scuttle panel where wires come out off the metal . you need to take off inner arches as well to seal up on a posts it splits down the post . need to dig out all old sealer and re do with new .
Jcrosskey
28
Wiltshire
Looked at pollen filter housing and the rubber bit around it was all mis shaped and wasn't covering the actual filter. Hopefully sorted it now tho
Josh Holden
11
Warwickshire
Iv had the pollen filter cover and doors leaking, there where puddles in the rear footwell :/ iv now removed the interior, carpet and sound deadening. I need some new sound deadening as I wrecked it trying to dry it. Does any one know where to get some from or anyone who has some? Thanks
