DTUK tuning box
Deleted member 11430
Rob the reason we send the photos is to show the recommended route we take to run the cables, my only concerned is if either if those 2 cables touch anything hot they could cause issues.
My recommendation is to follow the guide we send with the kit
Rob2k68
122
Rugby
Hi Andrew,
Thanks for the quick reply. The photos supplied were obviously my first port of call but on my car the box wouldn't physically fit between the battery and the air box so I had to improvise which pushed the install time to about an hour whilst I gave it some thought. Is Trevor the same dimensions as the previous unit ? The harness is tie wrapped to the original engine harness so I don't anticipate any heat issues.
Cheers.
Trevor sits in between the battery and airbox on every Leon we've tuned recently Rob, as I've said be careful as it's £60 for a new harness
Does anyone know if there any graphs for the 3 program's on the new Trevor
No, there is no way of visualising the maps on the new system Mark.
We switched the Skoda over to map2 plus 1 on Friday and the car felt a lot sharper on the Lower rpm over map 3 plus 1.
Havsgaard
186
Denmark
The few days i have been running on map 3+1, i would say the low rpm feels a bit stock-a-like. There's some more power, no question and not bad at all, but it might be more friendly to some peoples needs (like wifes) - and i dont wany wife to wheelspin in the driveway and end up in the garden next door. I will be running map 3+1 for a few more weeks, then i will try 2+1.
MarkBeatty72
88
Blyth, Northumberland
Andrew,
Thanks for the response. Do you have any comparision or description for each of the maps like what you have said about 2+1 pulling sharper on the lower RPM's. In the meantime might try 2+1 as 3+1 certainly pulls harder in the lower RPM's but then pulls evern harder at approx 3250RPM on my FR 184
addsLEON
51
So I recieved "Trevor" today and fitted it to my 184 fr and noticed a huge difference straight away. Can anyone recommend settings for tuning box?? I currently have it on P2+2 but I know some of you guys have been running them for a while and wanted some feedback on this?
Leonsc184
8
Hi all,
I have a Trevor for sale as I am changing cars!
PM me if interested with best offer.
Thanks,
madduffyx
348
I happened to be working 2 minutes from DTUK's office so popped in to say hello and Andrew kindly reflashed my crd-t with the latest map free of charge :) Quality new map, found the torque and acceleration to be a lot more linear than previous map, so big thumbs up guys! Cheers for your brilliant customer care. Highly recommended!
Fraczish
185
Looking for someone running a box on 1.4tsi 140, very tempted by this box, just intrested in what its like real world, the 1.4 for me is quite torquey down low but runs out of puff a bit further up the range....
andrew - what would you recommend for a '58 Golf 5 1.4 tsi 140?
my daughter's looking at remapping after christmas....was hoping for 180+bhp...
Hi Andrew,
We do have an FSR system available and the quoted figures are 168 and 260nm
Fraczish
185
New box ordered! Exciting times! From a quick look at figures I'm gestimating that this box will turn my 1.4 into more like the 1.8tsi? Also had a look at a 180 Ibiza cupra (0-60 7.0secs) mine would be over 100kgs lighter and 50nm more torque... Does that mean I could be looking at high 6's??? Seems a lot...
