2006 Ibiza FR TDi - Project Smke
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Front dampers are feeling really tired and almost feels like the OSF is bottoming out in some corners.
Was looking at coilovers and the Bilstein B12 kit but because it's a daily driver and i'm in my 30's now it needs to be comfortable and practical.
Going to go down the route of Eibach Pro springs so slight lowering, but not OTT matched with Bilstein B4 gas dampers on all corners.
Makes sense to do whilst the front end is in bits getting poly bushed and clutch fitted so think will fit new tie rods, ball joints and track rod ends all at the same time so it's nice and tight for a while :D
After all that, it's time for some engine performance mods and sort some of the bodywork out
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Cheers folks.
Trying to keep it subtle and comfortable as well with the mods.
Got the wheels powder coated again today as they had some scuffs and chips on the edges and i pranged one myself recently
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Yeah? Nice one. I had him do the exhaust on my last car as well. Simon's a good guy.
Bought these today
New OEM grade strut top bushings and bearings
Eibach Pro lowering springs.
Bilstein B4 dampers
My dampers are gone at the front so this should lower it slightly without being uncomfortable.
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Cheers Badger, looking forward to seeing it myself.
Think it's quite minimal on the FR but as it's a daily i didn't want it too stiff or too low
The standard ones are bottoming out on the front so made sense to replace it all the same time as fitting the poly bushes.
Going to have new tie rods, track rod ends and ball joints done as well.
Should make the front end feel as good as, if not better than new.
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Thanks mate.
Colour is down as Titanium according to the place that powdercoated them but it's Anthracite to me.
Colour changes slightly in certain lights like real Anthracite does.
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Cheers mate. Were you on the dyno as well?
I left a bit earlier as was shattered.
I got a picture of lots of the cars there and i'm sure i got at least one of yours.
Will upload the pics to the thread arranging the event when i get a chance.
wul3er
47
North Lanarkshire
Na didn't go on the dyno. I've only got a Cone filter and cat back stainless.
I had to leave early as well. I forgot I had someone coming to see me at 11.
I've got some pics too but I'll need to go through them and edit the regi out.
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Booked back into Simon's Custom Exhausts later this month for more exhaust work.
Getting another pipe made up so i have the option of using the baffled straight through backbox, or just a straight unbaffled pipe instead (running backbox just now)
Lacquer on door seems to be getting so thin it's failing on the driver side door as well. Not peeling, but washing off! A small patch appeared when i got it last year and it's getting bigger now.
Ahh right. I uploaded all the pics of the cars to my FB, but didn't edit any of the registrations out.
Do you want me to leave out the pics of yours when i post them in that thread?
I liked this one someone else got of my car (permission from them to use it)
Have you taken off your egr cooler ?
No yet. It's near the bottom of a long list of things to do, with not much time to do them i'm afraid :(
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
Last parts arrived so going to get it booked in for the below work asap.
Fit new bottom ball joints (Febi Bilstein)
Fit new track rod ends (Febi Bilstein)
Fit new strut top mounts & bearings (OEM)
Fit new dampers all round (Bilstein B4)
Fit new drop links (OEM)
Fit Eibach Pro lowering springs.
Fit new Sachs organic clutch kit, DMF and release bearing.
New gearbox oil.
Powerflex poly bush kit for ARB, bottom arms and lower engine mount.
Laser aligned
In the meantime, got this done at the weekend to make it sound more angry when i put the foot down
Hardcore
Diesel lover
Jul 31, 2013
130
West Scotland
So after hearing some grinding noises from my front wheel i decided to investigate and found this
Decided to get those TT calipers i have waiting to go on a good clean up
Before and after with the brass wheel
Some anti rust treatment
Leaving them to dry and the treatment to set for 24 hours. Gave them 2 coats.
Going to paint them silver tomorrow and pop some new bleed nipples in them
