mwflynn06
126
Leeds
Used my DA for the second time. Starting to get a better feel on how to use it. This is the result.
Bouncerbeater
Old enough to know better
Mar 15, 2013
1,303
Gloucestershire
Finally got around to fitting my fmic..
Took about three hours all in so not too much hassle at all.
Can instantly feel more mid to top end power.
Will have to get on with fitting my oversize TIP now
rob929
252
plymouth
Hired a rug doctor carpet cleaner to clean our house carpets but ended up doing the car seats instead. :whistle:Wow. It has transformed my seats. Look like new and my car smells like new.
rossi46
495
Kent
Ordered the following due to arrive this week!
10mm front and 15mm rear Hubcentric wheel spacers.
White line 24mm adjustable rear anti roll bar.
Forge red silicone upper boost hoses and turbo outlet hose.
Non resonated alloy turbo charge pipe.
dazjstuart
660
8
Aberdeen
Finally finished fitting the turbo and tip! New pagid discs on the front too. Complete coolant drain and new oil and filter. Seems to all be working working great so far, didn't push it too hard till the new turbo / discs bed in a bit but I seem to have the full complement of boost at long last!
Time to break out the polish I think and treat her to a clean!
dazjstuart
660
8
Aberdeen
P.s. Anyone know if there's a market for a k03s with a shagged hotside? Cold sides perfect zero play in shaft, it's just as tight as the new one. Problem is the wastegate sticks when the engines hot. It may just be the actuator as I see the rods a bit bent but I don't know. Do any of the companies that do rebuilds buy old turbos to recondition? 72k miles.
