What did you and your MK2 do today?
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
But do you know how it was before you put the springs on? ...and if whether you knacked it when you tinkered with it yourself hehehe
Well in the 12 months I've had the car there has been no sign of uneven tyre wear so if it was out i doubt it was by much, main issue was the camber.
Unlikely anything i did caused an issue, plus it was all 4 that were out not just the corner i failed to do :)
Sent from LG G2 using Tuppytalk
Rob_Talisman
MKII CR FR 170 FL Stage 2
Sep 2, 2013
811
North East
Ok here goes, ill do a brief write up here...
(You can get black ones too)
I have also ordered a piggyback fuse and 3m USB converter to hardwire it. When plugged in either by the supplied cig charger or to fuse box, the camera auto turns on with ignition and record straight away. It saves the file when turned off again.
Anyway a great camera for anyone who wants to record footage of drives or for protection during accidents etc. I won't add anymore as this probably isn't the right thread to put it on.
Black one on order.
3m USB Converter? any more details on that as id like all the wiring hidden out the way.
Think ill attach to the rear of the mirror.
STU3Y
1,271
Kent
Black one on order.
If you attach to the rearview you will have to play around with angle or pad out one side to make sure you get the best view. I currently just remove the sucker and take the unit in with me as they can be like sat navs and the car will get broken into just to steal the camera. Depends where you live I suppose!
The cigarette lighter charger is very long and can be run round the windscreen out of sight and plugged in, but i wanted to keep it free so I am awaiting delivery of these.
Piggy back fuse
http://m.ebay.co.uk/itm/251170198363
Usb converter
http://m.ebay.co.uk/itm/251177580267
Will plug the fuse holder into a spare holder in the fuse box in the dash, like I did the btcc running lights, then wire the usb converter to it and run that either up the A pillar or along the doorseals and headlining to the rearview mirror. Whichever is easier and will last well enough
Rob_Talisman
Sep 2, 2013
811
North East
Piggy back fuse
Usb converter
ordered both many thanks mate.
normal driving from work to home both are safe. anything other than that yes id remove too.
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,483
Northumberland
Just clayed the car with G3 Clay Mitt. Saw it in Halfords and looked it up quickly on detailing world. then thought...why not?!
Results: amazing! Much easier than a bar and worked a treat. Top tip
Jan 3, 2014
593
How much you pay for that mate?
Sent from my SM-N9005 using Tapatalk
jmc1976
2,363
wakefield, west yorks
Another ferry ride , home this time , current location f£%k knows
ne3e2yty
Sent from my RM-875_eu_euro1_212 using Tapatalk
