Hi mate, how are you getting on with the Philips unit?
Hi, the unit itself is very nice powered up, I had to go back to the seller about the GPS IGo8 software as it was failing to start but very promptly he gave me the solution (delete the POIs for the countries you don't need) and the handbrake cable tip seems to have been spot on.
My
problem and the reason why the unit isn't currently sitting in my car is that the fascia kit which I got and the double din cage sits in has much larger retaining clips than the Seat fascia I took out and I can't see any method by which they would fit other than cunning adaptation with a hacksaw and file. Obviously I'm not particularly keen to do this and have asked the supplier for his suggestions.
What people are going to say is that in the FAQ, point 3 is
"3) do a search on eBay for a VW Golf Mk5 fascia. (approx £9-15) This will fit in the SEAT sat-nav fascia adaptor and then you can put in your aftermarket headunit.
If installing a double-din unit then you will need to cut out the middle bar in the VW Golf fascia adaptor."
This kit unexpectedly doesn't contain this so I am wondering whether it would be better to get one of these and wait for the genuine Seat fascia part to arrive (it is on back order)
