Looking for a stereo..
Quaddragone
13
Hi The_saint, thanks for your reply!
I have been super busy lately with placement rotations..
Anyway, just wondering if you could post your sys.txt of the iGO 8.3.5? Cos I think I have some of the features off and would like to (compare your sys.txt / mine sys.txt) and re-enable them...
Looking forward to your reply
The_Saint
307
12
Cardiff
Here it is, some of the values are a bit puzzling but I was under the impression that playing with this generally doesn't help. (e.g. see http://fixmygps.info/forum/showthread.php?tid=4029&pid=30852#pid30852 )
[device]
type="nextg828"
[debug]
enable_roadshadow=1
show_residentonly=1
enable_roadsign=1
enable_landmark_occlusion=1
show_oneway_3d=1
show_oneway=1
show_gps_pos=1
show_signpost=1
background_navigation=1
screen_calibration=1
skip_eula=1
;max_memory=25000000
[map]
3d_max_tiltlevel=9000
stop_rotate_on_map_move=1
inertia_on_map_move=1
follow_gps=1
2dheadup=1
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_boundingrects=1
show_poi_areas=1
[navigation]
show_current_city=1
show_countrychange=1
autoreplan_action="AUTO"
gps_pos_to_road=1
[timezone]
patch_dst=1
[timezones]
use_timezone_setting_fix=1
use_new_timezone_ini=1
timezone_key="Time Zones"
[interface]
resolution_dir="400_240"
vga=1
[rawdisplay]
class="landscape"
highres=1
screen_x=800
screen_y=480
[interface]
laneinfo_signpost_enabled=1
[sound]
queue_length=200
ding=0
recalc_voice=0
Quaddragone
13
Hi The_Saint, thanks for posting your sys.txt, mine is the same except I had to replace the [sound] with
working=1
dev_channels=2
dev_bits=16
dev_smp_rate=48000
dev_buffer_size=9216
csv_voice_enabled=1
ding=1
effect_volume=255
guidance_volume=255
os_muted=0 ; 1 - sound off
os_volume=255
maneuver_chimes=0
media_volume=255
mic_volume=255
mute_os_key=0
queue_length=200
use_os_volume=1
user_volume=255
voice_volume=255
and that gave me voice navigation...
The_Saint
307
12
Cardiff
I never had any issues other than slow performance until I deleted all the foreign language files etc.
In the interests of science I tried following the advice at the link I put up in my last post, the unit wouldn't find a loading.bmp it was prepared to load with the exact settings the poster advises but it works perfectly for me with just the lines below in the sys.txt. the loading.bmp it is prepared to work with in the directory pointed to by 400_240 doesn't appear to be a valid format I can open.
[interface]
[rawdisplay]
screen_x=800
screen_y=480
Quaddragone
13
Thanks for the info. I am waiting for my UHC-1 sd card to reduce any bottleneck and will be clearing some of the redundant files like foreign languages etc :)
Quaddragone
13
Also been looking to get the latest fw update for the device, but no luck..even emailed and called philips and they couldnt help...
Quaddragone
13
Just read to the end of the other thread...seems like its not fully working yet...
With my limited knowledge, its highly unlikely I can achieve such feat :p
Quaddragone
13
I came across those BIOS too but have hold off updating it due to the reason you mentioned...
I was hoping there is a changelog as I have been experiencing some problem with the UNIcode layouts...But its not a big problem so I wont risk bricking the unit :D
Quaddragone
13
Time to try the bluetooth functions and do some fine adjustments to the unit, like sat nav volume etc :) and giving some TLC to the car :D
spb
The_Saint any idea if there is a way we can install a custom start up logo so instead of PHILIPS our car logo will appear? I am sure it can be done but any idea how?
